    MMM-TelegramBot : Control MM on Telegram
    47 Posts 20 Posters 24.0k Views 21 Watching
    • ? Offline
      A Former User @krisalexroberts
      @krisalexroberts By pledging? :)
      • michael5rM Offline
        michael5r Module Developer
        This is a great module - I’m adding Telegram support to all my modules shortly :thumbs_up:
        • lolobyteL Offline
          lolobyte
          Hello,
          can somebody help me with this module?
          here is my config.js entry including the MMM-Tools. Tools are running very well.
                                  module: 'MMM-Tools',
                                  position: 'bottom_right',
                                          device : "RPI", // "RPI" is also available
                                          refresh_interval_ms : 10000,
                                          warning_interval_ms : 1000 * 60 * 5,
                                          enable_warning : true,
                                          warning : {
                                                  CPU_TEMPERATURE : 65,
                                                  GPU_TEMPERATURE : 65,
                                                  CPU_USAGE : 75,
                                                  STORAGE_USED_PERCENT : 80,
                                                  MEMORY_USED_PERCENT : 80
                                          warning_text: {
                                                  CPU_TEMPERATURE : "The temperature of CPU is over %VAL%",
                                                  GPU_TEMPERATURE : "The temperature of GPU is over %VAL%",
                                                  CPU_USAGE : "The usage of CPU is over %VAL%",
                                                  STORAGE_USED_PERCENT : "The storage is used over %VAL% percent",
                                                  MEMORY_USED_PERCENT : "The memory is used over %VAL% percent",
                                  module: 'MMM-TelegramBot',
                                          telegramAPIKey : 'xxxxxxxxxxxxxxxmy_API_keyxxxxxxxxxxxxxxxxxxxx',
                                          allowedUser : ['my_Telegram_username without @'], // This is NOT the username of bot.
          The logs of MM2!
          0|mm  | [TELBOT] Error: ETELEGRAM
          0|mm  | { ok: false,
          0|mm  |   error_code: 400,
          0|mm  |   description: 'Bad Request: chat_id is empty' }
          0|mm  | ERR_RESPONSE { type: 'TEXT',
          0|mm  |   chat_id: undefined,
          0|mm  |   text: 'Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.' }
          0|mm  | { ok: false,
          0|mm  | { ok: false,
          0|mm  |   text: '`ERROR`\n```\nBad Request: chat_id is empty\n```\nat\n```\n{"type":"TEXT","text":"`ERROR`\\n```\\nBad Request: chat_id is empty\\n```\\nat\\n```\\n{\\"type\\":\\"TEXT\\",\\"chat_id\\":null,\\"text\\":\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\"}\\n```","option":{"disable_notification":false,"parse_mode":"Markdown","chat_id":"","text":"`ERROR`\\n```\\nBad Request: chat_id is empty\\n```\\nat\\n```\\n{\\"type\\":\\"TEXT\\",\\"chat_id\\":null,\\"text\\":\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\"}\\n```"}}\n```',
          0|mm  |   option:
          0|mm  |    { disable_notification: false,
          0|mm  |      parse_mode: 'Markdown',
          0|mm  |      chat_id: '',
          0|mm  |      text: '`ERROR`\n```\nBad Request: chat_id is empty\n```\nat\n```\n{"type":"TEXT","text":"`ERROR`\\n```\\nBad Request: chat_id is empty\\n```\\nat\\n```\\n{\\"type\\":\\"TEXT\\",\\"chat_id\\":null,\\"text\\":\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\"}\\n```","option":{"disable_notification":false,"parse_mode":"Markdown","chat_id":"","text":"`ERROR`\\n```\\nBad Request: chat_id is empty\\n```\\nat\\n```\\n{\\"type\\":\\"TEXT\\",\\"chat_id\\":null,\\"text\\":\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\"}\\n```"}}\n```' } }
          0|mm  | { ok: false,
          0|mm  | { ok: false,
          0|mm  |   text: '`ERROR`\n```\nBad Request: chat_id is empty\n```\nat\n```\n{"type":"TEXT","chat_id":null,"text":"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren."}\n```',
          0|mm  |   option:
          0|mm  |      chat_id: '',
          0|mm  |      text: '`ERROR`\n```\nBad Request: chat_id is empty\n```\nat\n```\n{"type":"TEXT","chat_id":null,"text":"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren."}\n```' } }
          0|mm  | { ok: false,
          0|mm  | { ok: false,
          0|mm  |   text: '`ERROR`\n```\nBad Request: chat_id is empty\n```\nat\n```\n{"type":"TEXT","text":"`ERROR`\\n```\\nBad Request: chat_id is empty\\n```\\nat\\n```\\n{\\"type\\":\\"TEXT\\",\\"text\\":\\"`ERROR`\\\\n```\\\\nBad Request: chat_id is empty\\\\n```\\\\nat\\\\n```\\\\n{\\\\\\"type\\\\\\":\\\\\\"TEXT\\\\\\",\\\\\\"chat_id\\\\\\":null,\\\\\\"text\\\\\\":\\\\\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\\\\\"}\\\\n```\\",\\"option\\":{\\"disable_notification\\":false,\\"parse_mode\\":\\"Markdown\\",\\"chat_id\\":\\"\\",\\"text\\":\\"`ERROR`\\\\n```\\\\nBad Request: chat_id is empty\\\\n```\\\\nat\\\\n```\\\\n{\\\\\\"type\\\\\\":\\\\\\"TEXT\\\\\\",\\\\\\"chat_id\\\\\\":null,\\\\\\"text\\\\\\":\\\\\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\\\\\"}\\\\n```\\"}}\\n```","option":{"disable_notification":false,"parse_mode":"Markdown","chat_id":"","text":"`ERROR`\\n```\\nBad Request: chat_id is empty\\n```\\nat\\n```\\n{\\"type\\":\\"TEXT\\",\\"text\\":\\"`ERROR`\\\\n```\\\\nBad Request: chat_id is empty\\\\n```\\\\nat\\\\n```\\\\n{\\\\\\"type\\\\\\":\\\\\\"TEXT\\\\\\",\\\\\\"chat_id\\\\\\":null,\\\\\\"text\\\\\\":\\\\\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\\\\\"}\\\\n```\\",\\"option\\":{\\"disable_notification\\":false,\\"parse_mode\\":\\"Markdown\\",\\"chat_id\\":\\"\\",\\"text\\":\\"`ERROR`\\\\n```\\\\nBad Request: chat_id is empty\\\\n```\\\\nat\\\\n```\\\\n{\\\\\\"type\\\\\\":\\\\\\"TEXT\\\\\\",\\\\\\"chat_id\\\\\\":null,\\\\\\"text\\\\\\":\\\\\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\\\\\"}\\\\n```\\"}}\\n```"}}\n```',
          0|mm  |   option:
          0|mm  |      chat_id: '',
          0|mm  |      text: '`ERROR`\n```\nBad Request: chat_id is empty\n```\nat\n```\n{"type":"TEXT","text":"`ERROR`\\n```\\nBad Request: chat_id is empty\\n```\\nat\\n```\\n{\\"type\\":\\"TEXT\\",\\"text\\":\\"`ERROR`\\\\n```\\\\nBad Request: chat_id is empty\\\\n```\\\\nat\\\\n```\\\\n{\\\\\\"type\\\\\\":\\\\\\"TEXT\\\\\\",\\\\\\"chat_id\\\\\\":null,\\\\\\"text\\\\\\":\\\\\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\\\\\"}\\\\n```\\",\\"option\\":{\\"disable_notification\\":false,\\"parse_mode\\":\\"Markdown\\",\\"chat_id\\":\\"\\",\\"text\\":\\"`ERROR`\\\\n```\\\\nBad Request: chat_id is empty\\\\n```\\\\nat\\\\n```\\\\n{\\\\\\"type\\\\\\":\\\\\\"TEXT\\\\\\",\\\\\\"chat_id\\\\\\":null,\\\\\\"text\\\\\\":\\\\\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\\\\\"}\\\\n```\\"}}\\n```","option":{"disable_notification":false,"parse_mode":"Markdown","chat_id":"","text":"`ERROR`\\n```\\nBad Request: chat_id is empty\\n```\\nat\\n```\\n{\\"type\\":\\"TEXT\\",\\"text\\":\\"`ERROR`\\\\n```\\\\nBad Request: chat_id is empty\\\\n```\\\\nat\\\\n```\\\\n{\\\\\\"type\\\\\\":\\\\\\"TEXT\\\\\\",\\\\\\"chat_id\\\\\\":null,\\\\\\"text\\\\\\":\\\\\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\\\\\"}\\\\n```\\",\\"option\\":{\\"disable_notification\\":false,\\"parse_mode\\":\\"Markdown\\",\\"chat_id\\":\\"\\",\\"text\\":\\"`ERROR`\\\\n```\\\\nBad Request: chat_id is empty\\\\n```\\\\nat\\\\n```\\\\n{\\\\\\"type\\\\\\":\\\\\\"TEXT\\\\\\",\\\\\\"chat_id\\\\\\":null,\\\\\\"text\\\\\\":\\\\\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\\\\\"}\\\\n```\\"}}\\n```"}}\n```' } }
          0|mm  | { ok: false,
          0|mm  |   text: '`ERROR`\n```\nBad Request: chat_id is empty\n```\nat\n```\n{"type":"TEXT","text":"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren."}\n```',
          0|mm  |   option:
          0|mm  |      chat_id: '',
          0|mm  |      text: '`ERROR`\n```\nBad Request: chat_id is empty\n```\nat\n```\n{"type":"TEXT","text":"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren."}\n```' } }
          0|mm  | { ok: false,
          0|mm  | { ok: false,
          0|mm  |   option:
          0|mm  |      chat_id: '',
          0|mm  | { ok: false,
          ^C
          and it’s never ending.
          What is wrong?
          • ? Offline
            A Former User @lolobyte
            @lolobyte
            Your telegrambot config is not completed. Read instructions of module on github
            • lolobyteL Offline
              lolobyte
              Hi, i know.
              But ongoing with step 4 is not possible because Telegranm don’t know the /commands or the /mychatid command!
              This is the reson why i don’t have actually the adminChatId.
              • ? Offline
                @lolobyte
                To make things simple, Disable other modules except MMM-TelegramBot.
                Then execute MM again. Show me which logs are displayed.
                • lolobyteL Offline
                  lolobyte
                  OK, here the new config .js only with telegram module.
                          units: "metric",
                  //                      module: 'MMM-Tools',
                  //                      position: 'top_right',
                  //                      config: {
                  //                              device : "RPI", // "RPI" is also available
                  //                              refresh_interval_ms : 10000,
                  //                              warning_interval_ms : 1000 * 60 * 5,
                  //                              enable_warning : true,
                  //                              warning : {
                  //                                      CPU_TEMPERATURE : 65,
                  //                                      GPU_TEMPERATURE : 65,
                  //                                      CPU_USAGE : 75,
                  //                                      STORAGE_USED_PERCENT : 80,
                  //                                      MEMORY_USED_PERCENT : 80
                  //                              warning_text: {
                  //                                      CPU_TEMPERATURE : "The temperature of CPU is over %VAL%",
                  //                                      GPU_TEMPERATURE : "The temperature of GPU is over %VAL%",
                  //                                      CPU_USAGE : "The usage of CPU is over %VAL%",
                  //                                      STORAGE_USED_PERCENT : "The storage is used over %VAL% percent",
                  //                                      MEMORY_USED_PERCENT : "The memory is used over %VAL% percent",
                  and here the log data.
                  pi@raspi-MM2:~ $ pm2 logs mm
                  [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
                  /home/pi/.pm2/logs/mm-error.log last 15 lines:
                  0|mm       |     at Request.emit (events.js:214:7)
                  0|mm       |     at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-iCloud-Client/node_modules/request/request.js:1161:10          )
                  0|mm       |     at emitOne (events.js:116:13)
                  0|mm       |     at Request.emit (events.js:211:7)
                  0|mm       |     at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-iCloud-Client/node_modules/request/request.js          :1083:12)
                  0|mm       |     at Object.onceWrapper (events.js:313:30)
                  0|mm       | TypeError: PythonShell is not a constructor
                  0|mm       |     at Class.loadDataFromAPI (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor/node_helper.js:216:17)
                  0|mm       |     at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor/node_helper.js:69:          9)
                  0|mm       |     at Socket.<anonymous> (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:113:11)
                  0|mm       |     at emitTwo (events.js:126:13)
                  0|mm       |     at Socket.emit (events.js:214:7)
                  0|mm       |     at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
                  0|mm       |     at _combinedTickCallback (internal/process/next_tick.js:131:7)
                  0|mm       |     at process._tickCallback (internal/process/next_tick.js:180:9)
                  /home/pi/.pm2/logs/mm-out.log last 15 lines:
                  0|mm       | starting network connection testing
                  0|mm       | Serving iCal
                  0|mm       | Serving iCal
                  0|mm       |
                  0|mm       | > magicmirror@2.6.0 start /home/pi/MagicMirror
                  0|mm       | > sh run-start.sh
                  0|mm       |
                  0|mm  | Starting MagicMirror: v2.6.0
                  0|mm  | Loading config ...
                  0|mm  | Loading module helpers ...
                  0|mm  | Initializing new module helper ...
                  0|mm  | Module helper loaded: MMM-TelegramBot
                  0|mm  | All module helpers loaded.
                  0|mm  | Starting server on port 8080 ...
                  0|mm  | Server started ...
                  0|mm  | Connecting socket for: MMM-TelegramBot
                  0|mm  | Sockets connected & modules started ...
                  0|mm  | Launching application.
                  the /commands or the /mychatid command doesn’t work.
                  second time restartin MM2
                  0|mm       |         _started: true,
                  0|mm       |         href: 'https://api.telegram.org/bot%3C718051157:AAFqI9VPBUE5W0FTYeZi770CWaq9mLYEBEQ%3E/getUpdates',
                  0|mm       |         req: [Object],
                  0|mm       |         ntick: true,
                  0|mm       |         response: [Circular],
                  0|mm       |         originalHost: 'api.telegram.org',
                  0|mm       |         originalHostHeaderName: 'host',
                  0|mm       |         responseContent: [Circular],
                  0|mm       |         _destdata: true,
                  0|mm       |         _ended: true,
                  0|mm       |         _callbackCalled: true },
                  0|mm       |      toJSON: [Function: responseToJSON],
                  0|mm       |      caseless: Caseless { dict: [Object] },
                  0|mm       |      read: [Function],
                  0|mm       |      body: { ok: false, error_code: 404, description: 'Not Found' } } }
                  • ? Offline
                    @lolobyte More error logs are needed. your mm-error.log is showing just last 15 lines.
                    If your file is too long, send me via email : eouia0819@gmail.com.
                    And If you don’t mind, send me your TelegramAPIKey also. (You can make new thing after my researching)
                    • lolobyteL Offline
                      lolobyte
                      I searche’d the log files and has found this 2:
                      mm-error.log is empty
                      mm-out.log
                      > sh run-start.sh
                      Loading config ...
                      Server started ...
                      Shutting down server...
                      Stopping module helper: MMM-TelegramBot
                      > sh run-start.sh
                      Loading config ...
                      Server started ...
                      • ? Offline
                        @lolobyte
                        Well,
                        mm-out.log
                        It means there’s no error in module on installation phase or running phase.
                        So I have to represent your issue but it might be related your account specific. So I need your TelegramBotAPI Key to represent your issue. Without it, I can help you only limitedly.
                        • 4 / 5
