    Hiding temp from the default currentweather.js module
    6 Posts 2 Posters 4.3k Views 3 Watching
    • rcollieR Offline
      rcollie
      Hey gang
      I’ve been banging my head against a wall here. I’ve been trying to get rid of (or at least hide) the current outdoor temp from the default currentweather.js module. I’m still relatively new to java so there’s a point where I go cross-eyed when it comes to something more complex like this one.
      In the end, I want to either add it to the left of the temp in the forecast.io module made by @dmcinnes, or stick it above it.
      I can’t figure out which sections go with which item. Would someone take pity on me and help me understand the breaks in the sections?
      For sake of ease, here’s the guts of the file.
      modedit: code removed to avoid irritating other users
        Mykle1 Project Sponsor Module Developer @rcollie
        @rcollie said in Hiding temp from the default currentweather.js module:
        By adding this to your custom.css file:
        .currentweather .bright {
        	display:none;
        You’ll get this:
        • rcollieR Offline
          rcollie
          Thanks @Mykie1. What would I do to also remove the weather icon?
            You’re welcome!
            I can’t test it at the moment but you can try this in your custom.css:
            .currentweather .wi weathericon {
            	display:none;
            • rcollieR Offline
              rcollie
              You’re a legend. Thanks
                You’re a legend
                In my own mind. :^')
