    Problem with MMM-ResRobot, it wont start(?)
    31 Posts 7 Posters 23.0k Views 7 Watching
      ajomannen @ajomannen
      @ajomannen
      I got it to work by adding an extra level of curly brackets and a comma after the closing square bracket:
      	module: "MMM-ResRobot",
      	header: "Departures",
      		routes: [
      		skipMinutes: 0,
      		maximumEntries: 6,
      		truncateAfter: 5,
      		apiKey: "xxxx"
      Is the example config on https://github.com/Alvinger/MMM-ResRobot incorrect?
        Alvinger @ajomannen
        @ajomannen sorry, the curly braces got lost in my copying. I have updated my previous post.
        • G Offline
          Gailby
          I can not get it working either, says fetching for quite some time now. I get a “MMM-ResRobot : Error: got 400 response” on starting server… strange. Anyone recognize the same output?
                                      routes: [
                                              {from: "740021656", to: "740020749"},   // ResRobot Station IDs of starting and destination station(s). At least one route must be defined.
                                              {from: "740000765", to: "740000284"},   // "from" is required but "to" is optional (set "to" to empty string to indicate all destinations)
                                              skipMinutes: 0,         // Skip departures that happens within the next  minutes.
                                              maximumEntries: 6,      // Number of departures to show on screen
                                              truncateAfter: 5,       // A value > 0 will truncate direction name at first space after  characters. 0 = no truncation
                                              apiKey: "1c01e8b8-92d0-4e05-86dc-a112d743ba5a"  // Your ResRobot apiKey
          • G Offline
            Gailby
            Ok, seems it didn’t want to handle several departures like previous post but only one:
                                        routes: [
                                                {from: "740000765", to: "740000284"}    // "from" is required but "to" is optional (set "to" to empty string to indicate all destinations)
            Still get error response:
            node_helper for MMM-ResRobot received a socket notification: CONFIG - Payload: {“updateInterval”:300000,“animationSpeed”:2000,“fade”:true,“fadePoint”:0.25,“apiBase”:“https://api.resrobot.se/v2/departureBoard?format=json&passlist=0",“apiKey”:“1c01e8b8-92d0-4e05-86dc-a112d743ba5a”,“routes”:[{“from”:“740000765”,“to”:“740000284”}],“skipMinutes”:0,“maximumEntries”:6,“truncateAfter”:5,“iconTable”:{“B”:"fa fa-bus”,“S”:“fa fa-subway”,“J”:“fa fa-train”,“U”:“fa fa-subway”,“F”:“fa fa-ship”}}
            Fetching new departure data for module: MMM-ResRobot
            node_helper for MMM-ResRobot received a socket notification: CONFIG - Payload: {“updateInterval”:300000,“animationSpeed”:2000,“fade”:true,“fadePoint”:0.25,“apiBase”:“https://api.resrobot.se/v2/departureBoard?format=json&passlist=0",“apiKey”:“1c01e8b8-92d0-4e05-86dc-a112d743ba5a”,“routes”:[{“from”:“740021656”,“to”:“740020749”}],“skipMinutes”:0,“maximumEntries”:6,“truncateAfter”:5,“iconTable”:{“B”:"fa fa-bus”,“S”:“fa fa-subway”,“J”:“fa fa-train”,“U”:“fa fa-subway”,“F”:“fa fa-ship”}}
              Alvinger @Gailby
              @Gailby I copied your first config but used my API key and it worked with no issues at all.
              Verify that you are using the correct API key.
              The 400 status code is usually because you are using the wrong key.
              • G Offline
                Gailby @Alvinger
                @Alvinger Thanx a lot, that did it! I got confused about the english translation of “ResRobot - Pole Schedules 2” and used ResRobot - Reseplanerare. My Bad :/
                  Alvinger @Gailby
                  @Gailby
                  Great to hear! (Jag dokumenterade på engelska så alla kunde förstå men då blir ju svenskar lite förvirrade! :-)
                  Maybe I should add the swedish name of the API key to the documentation as well.
                    ayeball @Alvinger
                    @Alvinger
                    Re: [Problem with MMM-ResRobot]
                    I have also problem with MMM-Resrobot . I use API-Key ResRobot - Stolptidtabeller 2. !
                    I got it to work now but i get stockholm stations … And i have use “ejdergatan"740025622” to redbergsplatsen" 740025673" Göteborg .
                    any idea? Kan svara på svenska också ;) Mvh
                      Alvinger @ayeball
                      @ayeball
                      Please post the appropriate part of config.js
                      Klipp in den relevanta delen av config.js så kan vi kolla på den.
                        ayeball @Alvinger
                        @Alvinger {
                        Fick det att funka nu ! . Va tydligen 3 ställen jag fick ändra cfg till id för stationerna samt app id . i config.js / mmm-resrobot.js och mmm-resrobot som ligger i mmm-resrobot master mappen .
                        Om jag vill ha en till tillagd som är det bara och upprepa följande kommando nedanför eller ? ;) Mvh
                        from: “station id”, // ResRobot Station ID (or a comma-separated string of IDs)
                        to: “station id”, // ResRobot Station ID of destination (or a comma-separated string of IDs)
                            position: "left",
                            header: "Spårvagn från Ejdergatan",
                                from: "740025622",   // ResRobot Station ID (or a comma-separated string of IDs)
                                to: "740025673", // ResRobot Station ID of destination (or a comma-separated string of IDs)
                                apiKey:"f1109bf4-187c-49e2-95ce-1ba1b6062388"  // Your ResRobot apiKey
                          Alvinger @ayeball
                          @ayeball
                          Bra att det funkar.
                          Du ska bara behöva ändra i den config.js som ligger i MagicMirror-mappen, inte i de andra.
                          För att ange flera rutter lägger du bara till en ny rad med:
                          {from:“”, to:“”},
                          På din config ser det ut som att fu använger en gammal version. Gör en git pull för att uppdatera. En av ändringarna är just formatet för att ange flera rutter. Se README.md för dokumentation.
