    Problem with Weather forecast
    47 Posts 14 Posters 48.9k Views 13 Watching
      roramirez Core Contributors @Sp4M
      So nice work guys! If somebody else can merge your changes with my PR or pushed other PR with theses changes go ahead.
      I’ll prefer to keep the same behavior if API not get 401
      Easy module development with MagicMirror Module Template
        Sp4M
        Thanks @roramirez
        Unfortunately it seems that daily API will not come back on the free version (and I guess that 99% percent of MM users use the free version of openweather)
        I created a pull request with the code I posted.
        • F Offline
          frank61BS @Sp4M
          @Sp4M
          Hm, with this version the module doesn’t come up at all ??
          Where should I configure the parameter maxNumberOfDays ??
          Btw I have a free acount on openweather
          • F Offline
            frank61BS @Sp4M
            @Sp4M
            Sorry it was my mistake.
            The modul seems to work.
            I think I copied it in a wrong way.
            • MichMichM Offline
              MichMich
              I just pushed a fix to the develop branch that should solve the weather forecast. It’s a bit of a hot fix while we are working on the new weather module.
              A new master release is planned to be released this weekend, so if you don’t want to install the develop version, hang tight.
                stevegoble @MichMich
                @MichMich fresh upgrade to 2.1.3 and using the entire sample config does not display the weather. I tried the develop branch and updated it with git pull but does the same. Was this fixed? Do I need a fresh build?
                • MarosM Offline
                  Maros
                  is it possible to show in weatherforecast units ?
                  it’s still showing just number f.e. 22
                  but i want to see 22°C
                  i tried to add units and also decimalSymbol but it still only numbers no sign of Celsius.
                  • 3 / 3
