    Add symboly/icon in a modul
    14 Posts 3 Posters 10.7k Views 4 Watching
    • D
      dominic
      Hi i want to add symboly/icon in a modul. But I can not do it. The symbol is said to be the result or it can be set over the config…can any one help me pleas ?
      This is the module code.
      'use strict';
      /* global Module */
      /* Magic Mirror
       * Module: MMM-mqtt
       * By Javier Ayala http://www.javierayala.com/
       * MIT Licensed.
      Module.register('MMM-mqtt', {
        defaults: {
          mqttServer: 'mqtt://test.mosquitto.org',
          loadingText: 'Loading MQTT Data...',
          topic: '',
          showTitle: false,
          title: 'MQTT Data',
          interval: 300000,
          postText: ''
        start: function() {
          Log.info('Starting module: ' + this.name);
          this.loaded = false;
          this.mqttVal = '';
          this.updateMqtt(this);
        updateMqtt: function(self) {
          self.sendSocketNotification('MQTT_SERVER', { mqttServer: self.config.mqttServer, topic: self.config.topic });
          setTimeout(self.updateMqtt, self.config.interval, self);
        getDom: function() {
          var wrapper = document.createElement('div');
          if (!this.loaded) {
            wrapper.innerHTML = this.config.loadingText;
            return wrapper;
          if (this.config.showTitle) {
            var titleDiv = document.createElement('div');
            titleDiv.innerHTML = this.config.title;
            wrapper.appendChild(titleDiv);
          var mqttDiv = document.createElement('div');
          mqttDiv.innerHTML = this.mqttVal.toString().concat(this.config.postText);
          wrapper.appendChild(mqttDiv);     // here add  the symbol
          return wrapper;
          if (notification === 'MQTT_DATA' && payload.topic === this.config.topic) {
            this.mqttVal = payload.data.toString();
            this.loaded = true;
            this.updateDom();
          if (notification === 'ERROR') {
            this.sendNotification('SHOW_ALERT', payload);
      • J
        j.e.f.f Project Sponsor Module Developer @dominic
        @dominic Are you trying to add the symbol as a font (e.g.: using Font Awesome) or are you trying to add the symbol as an SVG?
        • D
          dominic @j.e.f.f
          @j.e.f.f i try to ad a sysmbol as a font . But if you have an other idea, then it is ok.
          • J
            @dominic You need to include font-awesome in your getStyles() function.
            Here is an example:
            getStyles: function () {
              return ["font-awesome.css"];
            Then you can use classes to create a symbol:
            var symbol = document.createElement("span");
            symbol.className = "fa fa-calendar"; //font awesome calendar icon
            Take a look at the default calendar module to see how it’s been implemented there.
            https://github.com/MichMich/MagicMirror/tree/develop/modules/default/calendar
            • D
              dominic
              @j.e.f.f thank you. But one question, who can i call the Symbol, so that is Displayed before
              • J
                @dominic you can just insert text like so:
                    mqttDiv.innerHTML = "< span class='fa fa-calendar'>< /span>" + this.mqttVal.toString().concat(this.config.postText);
                (remove the spaces between the angle brackets and the words span and /span. I needed to put it there to get it to render in this post.)
                or you can append multiple elements to your mqttDiv object, like so:
                var symbolEl = document.createElement("span");
                var textEl = document.createElement("span");
                textEl.innerHTML = this.mqttVal.toString().concat(this.config.postText);
                mqttDiv.appendChild(symbol)
                mqttDiv.appendChild(textEl);
                up to you which way you want to do it. No advantage either way.
                • D
                  dominic
                  Thank you! I will test it later.
                  • D
                    dominic
                    It works!! Ehm is it possible to make it varriable, so i can choose the symbol with an entrie in the defaults ?
                     defaults: {
                       topic: '',
                       showTitle: false,
                       title: 'MQTT Data',
                       interval: 300000,
                       postText: ''
                    • J
                      @dominic indeed. it’s just a string, so you can have the string in the config, then insert it when you create the symbol object. Like so:
                      symbol.className = "fa " + this.config.symbol;
                      • D
                        dominic
                        Now with this code ( is the original code with added css file and with your part) i only get the text “loading MQTT DATA” before it has still worked with your code. Maybe it is to late or i don´t see the error…but if you can be so nice, can you add tell me wehre my error is and can you add the varribale code ? And thank you very much for your help. :)
                        'use strict';
                        /* global Module */
                        /* Magic Mirror
                        * Module: MMM-mqtt
                        * MIT Licensed.
                         defaults: {
                           topic: '',
                           showTitle: false,
                           title: 'MQTT Data',
                           interval: 300000,
                           postText: ''
                         start: function() {
                           this.mqttVal = '';
                          getStyles: function() {
                           return ["MMM-DHT-Sensor.css", "font-awesome.css"];
                           if (!this.loaded) {
                             return wrapper;
                           return wrapper;
                             this.loaded = true;
                             this.updateDom();
                        • J
                          @dominic can you look to see if there are errors in the console? Two places you can look: Errors from node_helper.js will be output to the pm2 logs. Type pm2 logs mm to monitor this. The second place to look for errors is in Electron’s console. Start MagicMirror in debug mode with npm start dev and you’ll get the screen divided into to halves. On the right side you’ll see a white panel. Click on “CONSOLE” and if there are any errors there they will be in red.
                          • D
                            dominic
                            @j.e.f.f said in Add symboly/icon in a modul:
                            with npm start dv i get this info, i dont get es divided screen in to halves.
                            pi@raspberrypi:~ $ npm start dev
                            npm ERR! Linux 4.9.41-v7+
                            npm ERR! argv “/usr/bin/node” “/usr/bin/npm” “start” “dev”
                            npm ERR! node v6.11.3
                            npm ERR! npm v3.10.10
                            npm ERR! path /home/pi/package.json
                            npm ERR! code ENOENT
                            npm ERR! errno -2
                            npm ERR! syscall open
                            npm ERR! enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
                            npm ERR! enoent This is most likely not a problem with npm itself
                            npm ERR! enoent and is related to npm not being able to find a file.
                            npm ERR! enoent
                            npm ERR! /home/pi/npm-debug.log
                            and with pm2 logs mm this one
                            pi@raspberrypi:~ $ pm2 logs mm
                            [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
                            ach with the other code
                            i get a symbol, only with the var version, it does not work.
                            • Mykle1M
                              Mykle1 Project Sponsor Module Developer @dominic
                              @dominic said in Add symboly/icon in a modul:
                              You have to cd in the MagicMirror directory first, then run npm start or npm start dev
                              • D
                                dominic @Mykle1
                                @Mykle1 Ah Thanks :D, now i have the console, but there is no error.
