    Add symboly/icon in a modul
    14 Posts 3 Posters 9.2k Views 4 Watching
      j.e.f.f Project Sponsor Module Developer @dominic
      @dominic can you look to see if there are errors in the console? Two places you can look: Errors from node_helper.js will be output to the pm2 logs. Type pm2 logs mm to monitor this. The second place to look for errors is in Electron’s console. Start MagicMirror in debug mode with npm start dev and you’ll get the screen divided into to halves. On the right side you’ll see a white panel. Click on “CONSOLE” and if there are any errors there they will be in red.
        dominic
        @j.e.f.f said in Add symboly/icon in a modul:
        with npm start dv i get this info, i dont get es divided screen in to halves.
        pi@raspberrypi:~ $ npm start dev
        npm ERR! Linux 4.9.41-v7+
        npm ERR! argv “/usr/bin/node” “/usr/bin/npm” “start” “dev”
        npm ERR! node v6.11.3
        npm ERR! npm v3.10.10
        npm ERR! path /home/pi/package.json
        npm ERR! code ENOENT
        npm ERR! errno -2
        npm ERR! syscall open
        npm ERR! enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
        npm ERR! enoent This is most likely not a problem with npm itself
        npm ERR! enoent and is related to npm not being able to find a file.
        npm ERR! enoent
        npm ERR! /home/pi/npm-debug.log
        and with pm2 logs mm this one
        pi@raspberrypi:~ $ pm2 logs mm
        [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
        ach with the other code
         mqttDiv.innerHTML = "< span class='fa fa-calendar'>< /span>" + this.mqttVal.toString().concat(this.config.postText);
        i get a symbol, only with the var version, it does not work.
          Mykle1 Project Sponsor Module Developer @dominic
          @dominic said in Add symboly/icon in a modul:
          You have to cd in the MagicMirror directory first, then run npm start or npm start dev
            dominic @Mykle1
            @Mykle1 Ah Thanks :D, now i have the console, but there is no error.
