    jquery not working on magic mirror
    5 Posts 3 Posters 3.6k Views 3 Watching
      Ryroro
      Hey guys, I just finish building the mirror and finish setting up all the basics of the magic mirror. The default modules run smoothly. However, whenever I try to run something related to jquery, the mirror just black out. I tired https://github.com/masters1222/mm-hide-all this guy’s module, with the library in it, but there is still nothing on display. I tried inserting source in the index.html, still nothing. And I find that the mirror will work again only if I delete reference to the library of jQuery.
      I use a raspbian system and installed the latest MagicMirror2.
      • strawberry 3.141S Offline
        did you try this?
        getScripts: function() {
        		return [this.file("js/jquery.js")];
        in mm-hide-all.js
          Ryroro
          thanks, but the whole thing is still black. Nothing’s showing up
            alexyak @Ryroro
            @Ryroro could you try run the MM with dev tools and check the console out for errors.
            npm start dev
              Ryroro @alexyak
              @alexyak
              thanks, everything is showing up again, except for the mm-hide-all module, and I don’t see any error on the console. But the button in the module just don’t show up.
