    arm64 version with automatic installer
    5 Posts 5 Posters 3.8k Views 6 Watching
      stacywebb
      Re: stronger Raspberry Pi 3 Alternatives
      For any of those that may be interested in running your MagicMirror on arm64 based hardware.
      Currently tested it on:
      • Pine64+
      • Rock64
      • Odroid C2
      Operating Systems:
      • DietPi
      • Xenial Mate
      • Xenial LXDE
      Command for the automatic installer:
      bash -c "$(curl -sL https://raw.githubusercontent.com/stacywebb/magicmirror_arm64/master/installers/arm64.sh)"
      I’ve written/rewritten several components of the original (majority for upgrades and arm64 support).
      There are still a few kinks to work out:
      • on Xenial Mate desktop bars are visible
      • pm2 may of may not work automatically depending on OS (works on Xenial Mate and LXDE)
      added some upgrades:
      • all required packages installed automagically
      • all required os updates installed automagically
      • all dependencies installed automagically
      Here is the link to the github repo also.
      Note: the raspberry installer script is still there theoretically it should work, however I haven’t tested it.
      As for benchmarks, I’ll leave that to someone else to play with.
      I’ll continue to update the repo when items are fixed. Let me know if you see issues.
      K 1 Reply Last reply Reply Quote 1
      • C Offline
        chrish1982
        Thanks for this, I’m having a bit of trouble though if anyone could help.
        I’m using an Odroid C2 with emmc storage and have run DietPi and Xenial, the installer runs fine and is successful but when I run sudo npm install && npm start I’m getting an error about electron. Will get more details later but if anyone has any ideas that would be great.
          Mykle1 Project Sponsor Module Developer @chrish1982
          @chrish1982 said in arm64 version with automatic installer:
          That would help ;-)
          However, it is not recommended that you run npm or install MM as sudo.
          Also, without knowing the nature of your electron error, it would pretty difficult to suggest how to correct it. Copy and paste the error here, in a code block, so it’s easy to read
          • ? Offline
            [[global:former-user]]
            @stacywebb
            This is not related to the topic,
            I’m considering to order ROCK64, but have some worries.
            Which peripherals do I need additionally? ROCK64 seems to have lack of WIFI and BT.
            Would you recommend “STARTER KIT” for a beginner? I used RPI3 and ATB before. I want equivalent usage as MagicMirror.
            • K Offline
              Kennetht @stacywebb
              @stacywebb On a Rock64 with Jessie installed and updated the automatic installer halts on the Chromium install.
              Is there a newer script available or any help?
              Installing dependencies …
              npm WARN notice [SECURITY] lodash has the following vulnerability: 1 low. Go here for more details: https://nodesecurity.io/advisories?search=lodash&version=3.10.1 - Run npm i npm@latest -g to upgrade your npm version, and then npm audit to get more info.
              chromedriver@2.41.0 install /root/MagicMirror/node_modules/chromedriver
              node install.js
              Only Linux 64 bits supported.
              npm ERR! code ELIFECYCLE
              npm ERR! errno 1
              npm ERR! chromedriver@2.41.0 install: node install.js
              npm ERR! Exit status 1
              npm ERR!
              npm ERR! Failed at the chromedriver@2.41.0 install script.
              npm ERR! /root/.npm/_logs/2018-08-22T08_52_01_523Z-debug.log
              root@rock64:~#
