    MMM-MPD
    7 Posts 3 Posters 6.2k Views 3 Watching
    • T
      timjong93
      Description
      I just created my first module and thought it would be nice to share it with you.
      Its an MPD (music player deamon) integration.
      It show the current state of your music player and songs coming up.
      It’s an early version, i still need to do some refactoring but if anyone would like to try it feel free to do so.
      Next up is propably an integration with the Home Assistant API.
      Screenshot
      alt text
      Download
      [card:timjong93/MMM-MPD]
      • gizmo90G
        gizmo90
        hi,
        it will not show me anything
        localhost:6600 says
        OK MPD 0.19.0
        ACK [5@0] {} unknown command "GET"
        ACK [5@0] {} Invalid word character
        but android mpd app listen to port 6600 and it works
        • T
          timjong93
          I will have a look this afternoon ;)
          • T
            timjong93 @gizmo90
            @gizmo90 Could you please specify in which logs you see these errors, and tell me a little bit more about which mpd server you are using? (Personaly i use mopidy.)
            I did push a maybe fix which was definitely a bug to github, so you can try to pull and run npm install. But i have not been able to reproduce your error with this limited amount of info.
            • gizmo90G
              gizmo90
              please correct me when i am wrong but i think this is wrong
              		module: "mpd_config",
              i think it has to be called:
              module:“MMM-MPD” like the folder or mpd_client like the js
              i have no idea what happend but after pi reboot, the node server wont start when your module is activated
              WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
              Loading module helpers ...
              No helper found for module: calendar_monthly.
              [SyntaxError: Block-scoped declarations (let, const, function, class) not yet supported outside strict mode]
              If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issu
              config:
              			module: "mpd_client",
              			position: "top_right",	// This can be any of the regions.
              			hostname: "localhost",
              			port: 6600
              folder and .js name are mpd_client
              i use raspian with standart MPD version from the repository
              • Y
                yawns Moderator @gizmo90
                @gizmo90
                No, the config was right.
                If you look at the file mpd_client.js you see this: Module.register("mpd_client",{ which defines the name of the module inside MagicMirror. But you are right, it should be consistent with module names and folder names to keep it clean
                • gizmo90G
                  gizmo90
                  ok now its correkt … i think. but now, the mirror is black.
                  node start without any error
