    Sync private iCloud calendar with MagicMirror
    162 Posts 58 Posters 426.1k Views 65 Watching
    • G Offline
      Gailby
      Doesn’t seem like they are empty in KB. However the first file has rw–r–r-- and the others only rw------ don’t know if these permissions affects the none fetching of data
        maestro82 @maestro82
        @maestro82 So I was able to get through the tutorial with no errors, all files discovered and synced. But when I run MagicMirror calendar says “Loading…” and never loads. I have changed interval to 5min in timer file. Any advise to troubleshoot?
        Thanks,
        • G Offline
          Gailby @Gailby
          @Gailby @ganther @Beh the ics files doesn’t seem to sync in Calendars… all files are empty. Have anyone resolved this?
            Beh
            Hey Guys, I’m sorry I can’t help you right now.
            I currently have my examination period at my university. So I’m super busy right now… I’ll be able to help in a week or so…
            • G Offline
              ganther
              @Gailby no, same behavior here.
              @beh Thank you and good luck for your exams.
                Solved this issue by using “http:” not “https:” in calendar url but now my calendar shows no events. I looked into the actual “modules/calendars/****.ics” file and it contains multiple events. Any suggestions?
                • G Offline
                  ganther @maestro82
                  @maestro82
                  Did you check your calendar-url in conf/config.js?
                  My calendar is running now correctly. Don‘t know why but now my ics-file isn‘t empty anymore.
                    maestro82
                    So . . . . . . restarted the mirror and now it works. Moving on to adding other calendars, wish us luck.
                      maestro82
                      So I have three separate calendars linked to ical, running on my magic mirror. I see events from all three calendars, but many events are missing. Any ideas?
                      • E Offline
                        E3V3A @maestro82
                        @maestro82 said in Sync private iCloud calendar with MagicMirror:
                        You are probably limiting the number of calendar items shown in your calendar config. (IDK what is the default, but perhaps only 10-15 which for 3 cals can be easily overloaded.)
                        “Everything I do (here) is for free – altruism is the way!”
                        MMM-FlightsAbove, MMM-Tabulator, MMM-Assistant (co-maintainer)
                          maestro82 @E3V3A
                          I have several reoccurring events on the same day, only one of each event is showing up. The number of events is set at 10 but it is going out at least 4 months with that set. It should only go out about 3 weeks with 10 events listed. I’ll try raising the number of events and limiting the time.
                          • P Offline
                            paddyhughes
                            This post is deleted!
                            • P Offline
                              paddyhughes @paddyhughes
                              • P Offline
                                paddyhughes
                                Hi
                                So i am getting stuck with this and don’t know how to fix the issue.
                                The UUID is beside my Calendar and in my iCloud this is my default one.
                                but the one i want to use is home (Home Calendar) but No UUID shows up
                                same goes for the work one.
                                The only one i am interested in is the Home Calendar
                                pi@raspberrypi:~/MagicMirror $ vdirsyncer discover
                                Discovering collections for pair iCloud_to_MagicMirror
                                Mirror:
                                iCloud:
                                  - "tasks" ("Reminders")
                                  - "AE********-E**4-4D**-A**4-*****************" ("Calendar")
                                  - "home" ("Home Calendar")
                                  - "work" ("Work")
                                warning: No collection "HERE-GOES-THE-UUID-OF-THE-CALENDAR-YOU-WANT-TO-SYNC" found for storage Mirror.
                                Should vdirsyncer attempt to create it? [y/N]:
                                Thanks for any help given :)
                                • P Offline
                                  Last issue resolved
                                  So my issue not really an issue just me expecting something different than what i got when i ran vdirsyncer discovery
                                  So the example on page 1 looks like this
                                  Mirror:
                                  iCloud:
                                    - "25CB285C-E163-4E0E-B420-C3FB469B7C00" ("Calendar 1")
                                    - "9221FEE8-E8B4-4D07-9402-8638529919EC" ("Calendar 2")
                                    - "953A5477-E405-4ED6-A5C3-473444EACC95" ("Calendar 3")
                                  warning: No collection "9221FEE8-E8B4-4D07-9402-8638529919EC" found for storage Mirror.
                                  With all the Calendars having a string for UUID E.G. 9221FEE8-E8B4-4D07-9402-8638529919EC
                                  And this is what i got
                                  Mirror:
                                  iCloud:
                                    - "9221FEE8-E8B4-4D07-9402-8638529919EC" ("Calendar")
                                    - "work" ("Work")
                                  Now what i didn’t know was that i did get a return of UUID for each Calendar
                                  (Reminders) UUID is "tasks"
                                  (Calendar) UUID is "9221FEE8-E8B4-4D07-9402-8638529919EC"
                                  (Home Calendar) UUID is "home"
                                  Hope this helps other people in the future.
                                  took me a bit of digging around.
                                    maestro82
                                    paddyhughes,
                                    Had the exact same issue.
                                    Had one calendar called “worK”, all the rest had the long UUID names.
                                    I keep looking for the “work” calendar, of course it’s UUID was “work”.
                                    Put that in and now it works.
                                    Some lessons are learned the hard way.
                                    Maestro-82
                                    • P Offline
                                      paddyhughes @maestro82
                                      Ya kept thinking I did something wrong set up 3 different Rpi thinking I did something some were in the code to mess up. Finally got it working ;)
                                      paddyhughes,
                                      Maestro-82
                                        Devert
                                        Have any1 made a video how to set it up, I have some problems? :-D
                                        • P Offline
                                          paddyhughes @Devert
                                          Hi what’s the issue
                                          @Devert
                                          • F Offline
                                            Fenis
                                            I saw someone back on page 1 getting this error but not a solution:
                                            Traceback (most recent call last):
                                            File “/usr/bin/vdirsyncer”, line 7, in
                                            from vdirsyncer.cli import main
                                            ImportError: No module named ‘vdirsyncer’
                                            In answer to the reply of if I added python3 to the executable, I already have.
                                            • 8
                                            • 9
                                            • 3 / 9
