    Raspberry Pi Config Help - Unable to find - [SeatDefaults] To add the following line below xserver-command=X -s 0 -dpms
    5 Posts 3 Posters 4.5k Views 3 Watching
    • I Offline
      IDCreate
      Hi so I’m slowly getting into configuring my Raspberry Pi.
      I’m running Raspbian Stretch with desktop
      Image with desktop based on Debian Stretch
      Version: September 2017
      Release date: 2017-09-07
      Kernel version: 4.9
      Release notes: Link
      I’m following the details on this page https://github.com/MichMich/MagicMirror/wiki/Configuring-the-Raspberry-Pi
      I’m at the section for the screensaver and I’m at the step below.
      Add the following line below [SeatDefaults]
      But I’ve typed everything in correctly but I’m unable to find the line [SeatDefaults]
      at the top of the open screen reads
      GNU nano 2.7.4 File: /etc/lightdm/lightdm.conf
      Any help would be greatly appreciated.
        j.e.f.f Project Sponsor Module Developer @IDCreate
        @IDCreate I never got the screensaver to disable properly with the configs as you have tried. I instead installed XScreensaver and then used that to disable screensaver and energy savings screen blanking.
        I 1 Reply Last reply Reply Quote 1
        • I Offline
          IDCreate
          This post is deleted!
          • I Offline
            IDCreate @j.e.f.f
            @j.e.f.f
            Thanks very much j.e.f.f that’s very helpful advice. I’m pleased I’m not the only one that has had this issue. I couldn’t even find the code line [SeatDefaults] on the page /etc/lightdm/lightdm.conf . I’ll try your suggestion, Mykle1 had also suggested this option to me but I just wanted to dig a little deeper and find out why [SeatDefaults] was not in the script for GNU nano 2.7.4 File: /etc/lightdm/lightdm.conf
            I’m sure there’s probably a obvious explanation for it.
            So how do I install on my Raspberry Pi 3 and is it suitable.I’m running Raspbian Stretch with desktop
            Kernel version: 4.9
            Release notes: Link
            • E Offline
              efevee
              check file by:
              sudo nano ~/.config/lxsession/LXDE-pi/autostart
              if it includes:
              @xscreensaver -no-splash
              then just comment it by adding #
              #@xscreensaver -no-splash
              if it doesn’t work install xscreensaver:
              sudo apt-get install xscreensaver
