Raspberry Pi Config Help - Unable to find - [SeatDefaults] To add the following line below xserver-command=X -s 0 -dpms
5 Posts 3 Posters 4.1k Views 3 Watching
  • I Offline
    IDCreate
    Hi so I’m slowly getting into configuring my Raspberry Pi.
    I’m running Raspbian Stretch with desktop
    Image with desktop based on Debian Stretch
    Version: September 2017
    Release date: 2017-09-07
    Kernel version: 4.9
    Release notes: Link
    I’m following the details on this page https://github.com/MichMich/MagicMirror/wiki/Configuring-the-Raspberry-Pi
    I’m at the section for the screensaver and I’m at the step below.
    Add the following line below [SeatDefaults]
    But I’ve typed everything in correctly but I’m unable to find the line [SeatDefaults]
    at the top of the open screen reads
    GNU nano 2.7.4 File: /etc/lightdm/lightdm.conf
    Any help would be greatly appreciated.
    J 1 Reply Last reply Nov 2, 2017, 3:06 AM Reply Quote 0
      j.e.f.f Project Sponsor Module Developer @IDCreate
      @IDCreate I never got the screensaver to disable properly with the configs as you have tried. I instead installed XScreensaver and then used that to disable screensaver and energy savings screen blanking.
      I 1 Reply Last reply Nov 2, 2017, 9:44 PM Reply Quote 1
      • I Offline
        IDCreate
        • I Offline
          IDCreate @j.e.f.f
          @j.e.f.f
          Thanks very much j.e.f.f that’s very helpful advice. I’m pleased I’m not the only one that has had this issue. I couldn’t even find the code line [SeatDefaults] on the page /etc/lightdm/lightdm.conf . I’ll try your suggestion, Mykle1 had also suggested this option to me but I just wanted to dig a little deeper and find out why [SeatDefaults] was not in the script for GNU nano 2.7.4 File: /etc/lightdm/lightdm.conf
          I’m sure there’s probably a obvious explanation for it.
          So how do I install on my Raspberry Pi 3 and is it suitable.I’m running Raspbian Stretch with desktop
          Kernel version: 4.9
          Release notes: Link
          • E Offline
            efevee
            check file by:
            sudo nano ~/.config/lxsession/LXDE-pi/autostart
            if it includes:
            @xscreensaver -no-splash
            then just comment it by adding #
            #@xscreensaver -no-splash
            if it doesn’t work install xscreensaver:
            sudo apt-get install xscreensaver
