    MM is eating all memory and crash!
    18 Posts 5 Posters 10.8k Views 4 Watching
    • emloweE Offline
      emlowe Module Developer
      $ uptime
       21:34:37 up 37 days, 58 min,  3 users,  load average: 0.08, 0.13, 0.09
      $ cat /etc/issue
      Raspbian GNU/Linux 8 \n \l
      $ uname -a
      Linux raspberrypi 4.9.35-v7+ #1014 SMP Fri Jun 30 14:47:43 BST 2017 armv7l GNU/Linux
      $ free -m
                   total       used       free     shared    buffers     cached
      Mem:           923        878         44        149         64        487
      -/+ buffers/cache:        326        596
      Swap:           99         99          0
      $ df -k
      Filesystem     1K-blocks    Used Available Use% Mounted on
      /dev/root        5863924 4248140   1294864  77% /
      devtmpfs          468148       0    468148   0% /dev
      tmpfs             472756  147656    325100  32% /dev/shm
      tmpfs             472756   12364    460392   3% /run
      tmpfs               5120       4      5116   1% /run/lock
      tmpfs             472756       0    472756   0% /sys/fs/cgroup
      /dev/mmcblk0p6     66528   21418     45110  33% /boot
      tmpfs              94552       0     94552   0% /run/user/1000
      tmpfs              94552       0     94552   0% /run/user/1001
      /dev/mmcblk0p5     30701     463     27945   2% /media/elowe/SETTINGS
       $ npm ls | grep -i magicmirror
      magicmirror@2.1.3
      $ npm ls | grep electron
      ├─┬ electron@1.7.5
      │ ├─┬ electron-download@3.3.0
      │ ├─┬ electron-chromedriver@1.6.0
      │ │ ├── electron-download@3.3.0 deduped
      │ │ │ └── electron-to-chromium@1.3.24
      Modules:
      • clock
      • currentweather
      • weatherforecast
      • MMM-MyScoreboard
      • MMM-EnphaseEnvoy
      • MMM-CalenderExt
      • MMM-AirNow
      • MMM-AutelisPentair
      • MMM-Globe
      • MMM-Remote-Control
      • MMM-PIR-Sensor
      • emloweE Offline
        Oh, and MM specifically is up for 20days:
        pm2 show mm
         Describing process with id 0 - name mm
        │ status            │ online                               │
        │ name              │ mm                                   │
        │ restarts          │ 6                                    │
        │ uptime            │ 20D
        • yawnsY Offline
          yawns Moderator @juergschwarz
          @juergschwarz
          Uninstall PiHole. If you search this forum for PiHole you will find two other threads with similar memory issues, both related to PiHole. After removing it the issue was gone.
          Mykle1M J 2 Replies Last reply Reply Quote 1
            juergschwarz @emlowe
            @all Ok sorry. Now my realy newest installation on Raspi 3 stretch wiht realy original config.js and no additional modules or other changes:
            pi@raspi32:~/MagicMirror $ npm ls | grep electron
            ├─┬ electron@1.7.9
            │ │ │ └── electron-to-chromium@1.3.27
            PageSize:4KB     RAM-Memory  Swap-space     High-Memory     Low-Memory                                    │
            │ Total in MB           927.3       100.0     - not in use   - not in use                                   │
            │ Free  in MB           424.9       100.0        │
            │ Free Percent           45.8%      100.0%        │
            │ Linux Kernel Internal Memory (MB)        │
            │                        Cached=     254.6     Active=     259.0                                            │
            │ Buffers=      36.2 Swapcached=       0.0  Inactive =     203.0                                            │
            │ Dirty  =       0.1 Writeback =       0.0  Mapped   =     147.6                                            │
            │ Slab   =      25.3 Commit_AS =    1412.1 PageTables=       4.6                                            │
            │ Top Processes Procs=161-mode=3-1=Base 3=Perf 4=Size 5=I/O[RootOnly] u=Args────────────────────────────────│
            │  PID    %CPU  Size   Res   Res   Res   Res Shared   Faults  Command                                       │
            │          Used    KB   Set  Text  Data   Lib    KB  Min  Maj                                               │
            │     922 354.8   297m   98m52660   131m    0 56268  249    0 electron                                      │
            │     928   5.4   295m69924 52660   143m    0 48540  111    0 electron                                      │
            │     865   4.4   454m85120 52660   297m    0 58716    0    0 electron                                      │
            │     896   2.0  6156  3828   156  3572     0  1572    0    0 nmon                                          │
            │     521   1.5   134m43540  1896 62820     0 21740    0    0 Xorg
            Now i will check it out with jessie :-(
              Mykle1 Project Sponsor Module Developer @yawns
              This post is deleted!
                juergschwarz @yawns
                @yawns Thanks. But last “overnight” test with only original config.js also crashed with stretch. So now a new test with jessie looks much better. Including pi-hole. It runs since 22 mins and 47% free ram. :-)
                yawnsY 1 Reply Last reply Reply Quote 0
                • yawnsY Offline
                  @juergschwarz
                  Thanks for your feedback, good to know. So one more reason against Stretch
                    Mykle1 Project Sponsor Module Developer @Mykle1
                    @Mykle1 said in MM is eating all memory and crash!:
                    Use Jessie, not Stretch
                    I rest my case. :-)
