    RPI and HDMI->VGA converters..
    7 Posts 3 Posters 4.9k Views 3 Watching
    • G Offline
      gshimself
      Hi guys. Im in need of your help.
      Since I’ve build my mirror I have used 3 different HDMI -> VGA converters. (I got a http://www.ebay.com/itm/LCD-Controller-Board-DIY-Kit-RTD2270L-Driver-LVDS-Inverter-Turn-LCD-to-Monitor-/110925504614 as a endpoint).
      The first converter had a external powersupply. It work… For a day. Then it started blinking/flashing and was unstable pitchure and I saw that my mirror did not enjoy it. Bad power voltage and so on.
      Next converter i used is bugged on the RGB scale and shows the green color ALL THE TIME. This means some problems.
      Now, now I have bought a legit HDMI>vga converter from “The Pi Hut” or something. Now I only get “NO SIGNAL” on my display. And even on my regular TV-display
      I know that the converter works (tried in my computer and PS4) But It’s just my RPI2 that it doesnt work on… I have googled far and beyond with no resualts. I have tried edit the “/boot/config” file but no help…
      To the question: Have anyone been in my position? Does anyone know why this happend? RPI power problems? is it the LCD Controllerboard togheter?
      • G Offline
        gshimself
        Update…
        Now I know it’s something to do with my RPI… I borrowed a friends RPI (with my screen, SD-card, converter, enverything) it works like a charm. And he got the same RPI model.
        Someone know what could fix the problem?
        • K Offline
          kckndrgn
          Best i can say is, have you done an update and upgrade recently to your Pi (assuming you are on Rasbian or NOOBS OS)?
          sudo apt-get update
          sudo apt-get upgrade
          and make sure all drivers and configurations are current?
          Might start with a new installation of the Pi OS and go from there.
          May also need to try to find the differences in the configurations between your Pi and your friends.
          • G Offline
            gshimself @kckndrgn
            @kckndrgn Thanks for replying!
            I’ve done a update/upgrade but same resaults, and yes, I’ve reinstalled Jessie on my SD card. But before I reseted my SD-card I tried it in his RPI and it worked. So
            My card -> His RPI, WORKS
            His cars -> His RPI, WORKS
            My C -> my rpi, NO
            His C -> ^^^^, NO.
            So it’s something with my hardware to do but can’t figure out how and why… It’s not like there is a BIOS reset anywhere either. :(
            And the powersupply should be good when I’ve used the same stuff on his RPI when it works. It’s so weird. It’s just a video output.
            • K Offline
              kckndrgn
              Sounds like you have a bad Pi then.
              Don’t know if there is any support in the Pi/Linux world but maybe you can use a USB to VGA adapter? I’ve got one on my PC (running winblows) for a dual monitor setup.
              • KnoxK Offline
                Knox
                There is also this little beauty
                https://www.pi-supply.com/product/gert-vga-666-hardware-vga-raspberry-pi/
                it uses the gpio pins instead of the hdmi output.
                • G Offline
                  gshimself @Knox
                  @Knox I’ve thought about that but just that I’ve tried 3 different converters makes me mad when it doesn’t work for some unknown reason. But maybe I just have to accept it and buy one. :)
