    MagicMirror not working anymore
    9 Posts 3 Posters 4.9k Views 3 Watching
      AnduriI
      Hey there,
      I tried to get the MMM-Motion-Detection working but did not succeed so far. But now my MagicMirror is not starting anymore. Maybe I did some additional changes, I’m not shure if there was anything important during tests. I got these logs from pm2 monit:
      MagicMirror >     at Module._compile (module.js:570:32)                                         x
      MagicMirror >     at Object.Module._extensions..js (module.js:579:10)                           x
      MagicMirror >     at Module.load (module.js:487:32)                                             x
      MagicMirror >     at tryModuleLoad (module.js:446:12)                                           x
      MagicMirror >     at Function.Module._load (module.js:438:3)                                    x
      MagicMirror >     at Module.require (module.js:497:17)                                          x
      PM2 > App [MagicMirror] with id [0] and pid [4704], exited with code [1] via signal [SIGINT]    x
      PM2 > Starting execution sequence in -fork mode- for app name:MagicMirror id:0                  x
      PM2 > App name:MagicMirror id:0 online                                                          x
      MagicMirror > Error: ENOENT: no such file or directory, open 'package.json'                     x
      MagicMirror >     at Error (native)                                                             x
      MagicMirror >     at Object.fs.openSync (fs.js:642:18)                                          x
      MagicMirror >     at Object.fs.readFileSync (fs.js:510:33)                                      x
      MagicMirror >     at Object. (/home/pi/MagicMirror/js/app.js:15:32)                  x
      Can anyone help me with that error? For me it looks like a problem in the core /js/app.js, but I#m a noob on these things…
      Regards,
      Anduril
      Mykle1M strawberry 3.141S 2 Replies Last reply Reply Quote 0
        Mykle1 Project Sponsor Module Developer @AnduriI
        @AnduriI said in MagicMirror not working anymore:
        Maybe you should reinstall MM. It takes less than 30 minutes.
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @AnduriI
          Error: ENOENT: no such file or directory, open ‘package.json’
            AnduriI
            @mykle1 so simply rm -r MagicMirror? Or do I have to clean anything else before reinstall?
            @strawberry the file itself looks quite normal and I don’t know what to look for. No entry for /js/app.js as far as I see. Maybe you can give me a hint?
              @AnduriI
              I’ve reinstalled without removing a thing, wanting to save certain things from a previous install. You can do this by simply renaming your current MagicMirror folder.
              If you want to completely remove your previous installation:
              rm -rf MagicMirror
                AnduriI
                well I did move the old folder and did a fresh install with the installer script, but it still gives the same errors. Maybe I did something wrong during installation of the dependencies of MMM-Motion-Detection. Any clue of what that might be or where I can find a log that might shine some light on?
                  @AnduriI
                  Hold on. Did you try to install MMM-Motion-Detection again? Or are you saying you have errors immediately following the install of MagicMirror?
                  Can you post your terminal output?
                    AnduriI
                    well I’m not shure what happened, but I think I called npm install python-shell instead of just using npm installinside the module folder (which would have installed python-shell correctly.
                    I just started from scratch and took a fresh jessie image.
                      @AnduriI
                      Uhh . . .
