    config setup
    2 Posts 1 Posters 1.1k Views 1 Watching
    • N Offline
      navyvette87
      In the weather sections there is " on each end of the comment, but when I added the traffic modules there is ’ on each end, Now I get a syntax error message when I try to start magicmirror. Should the traffic modules be changed to " on each end? I copied everything from the modules page.
      module: “currentweather”,
      position: “top_right”,
      locationID: “”, //ID from http://www.openweathermap.org/help/city_list.txt
      appid: “6ed9d867d3ba972c013edecdef1e685a”
      module: “weatherforecast”,
      header: “Weather Forecast”,
      module: ‘MMM-GoogleMapsTraffic’,
      position: ‘top_left’,
      key: ‘AIzaSyBO???4Z_gDUSKUEfLKep0E’,
      lat: 3?.??436614,
      lng: -1??.???13961,
      height: ‘300px’,
      width: ‘300px’
      module: ‘MMM-Traffic’,
      position: ‘middle_center’,
      classes: ‘bright medium’, //optional, default is ‘bright medium’, only applies to commute info not route_name
      api_key: ‘AIzaSyD-WlWr2VySiCj6OnZnVPCAMw5r1qdTBvM’,
      mode: ‘driving’,
      origin: ‘???’,
      destination: ‘???’,
      mon_destination: ‘???’,
      fri_destination: ‘???’,
      arrival_time: ‘0800’, //optional, but needs to be in 24 hour time if used.
      route_name: ‘Home to Work’,
      changeColor: true,
      showGreen: false,
      limitYellow: 5, //Greater than 5% of journey time due to traffic
      limitRed: 20, //Greater than 20% of journey time due to traffic
      traffic_model: ‘pessimistic’,
      interval: 120000, //2 minutes
      showWeekend: false,
      allTime: false
      • N Offline
        navyvette87
        OK i retried it with all the ’ replaced with ", still nothing. When i restart it after saving the config, it startes with a disk chk, then continues. When I replaced with the ", it restarts, but when I try to run node serveronly, it says syntax error.
