    Showing temperature from php file
    6 Posts 3 Posters 4.1k Views 4 Watching
      12wsx
      May I please someone to write simple module to show temperature from this link
      http://solartemp.no-ip.org:3000/lcdfeed.php?key=AAaaAAaaAA&group=e28ca223
      it is simple text. or maybe ther is a module which can simply adapt. I tried use MMM-Rest module but it is not starting “module loading” I’m very newbie in magic mirror and not a programmer so i can’t do it by my self.
      Regards
      Daniel
      • Y
        yawns Moderator
        https://forum.magicmirror.builders/topic/5743/mmm-solartemp
        like this? ;)
        Configuration like this:
        			module: "MMM-Solartemp",
        			position: "bottom_right",
        			header: "Solartemp",
        				baseURL: "http://solartemp.no-ip.org:3000/lcdfeed.php",
        				key: "AAaaAAaaAA",
        				group: "e28ca223"
        Could you please explain a bit more which sensors this module is using? Maybe others could use it as well.
          12wsx
          @12wsx said in Showing temperature from php file:
          Thank You Very Very much! it works great!
          This project is Nettemp- smart home project from poland.
          A lots of stuff- ds18b20, bme280, Air quality PMSx003, DIY Meteo by@pimowo- lightning sensor AS3935. Power, water, electricity reading and many many others.
          I Have only one question- how to change font ?
          • Y
            yawns Moderator @12wsx
            @12wsx
            Either you manipulate MMM-Solartemp.css in module folder ~/MagicMirror/modules/MMM-Solartemp or you modify custom.css in ~/MagicMirror/css
             .figures {
            	 font-family: "Times New Roman" !important;
            If you use the second option you are not running into problems if there is an update to the module.
            • O
              onetwankyfive
              this looks pretty cool
              http://techfreak.pl/nettemp/
                12wsx
                next question.
                is it Possible to use this module two times in one MM?
                I want to use it on left for home sensor and on right for own meteo station and air quality?
