    • Search
    Possible Issue: MMM-GoogleAssistant with recent Google Assistant SDK update
    Troubleshooting
    • T
      teamreflect last edited by teamreflect
      Tried installing the MMM-GoogleAssistant today and tried to make it with the work with new google assistant sdk update… I ran in to this following error code:
      File "assistant.py", line 133, in
        main()
      File "assistant.py", line 130, in main
        init_googleAssistant()
      File "assistant.py", line 124, in init_googleAssistant
        with Assistant(credentials) as assistant:
      TypeError: __init__() missing 1 required positional argument: 'device_model_id'
      hello from python!!
      any ideas on what is causing the problem?
      • R
        Raddy last edited by
        I’m having the same issue. I followed the instructions listed link text here and can get the sample assistant script to run from Google, but when I run the assistant.py script, I get the same error as above.
        • R
          Raddy last edited by Raddy
          Solved it!
          The SDK update changed the assistant initiation call. You registered a device_model_id (“Raddys-magic-mirror-device-id” for example) in the original instructions, so you have to add that to the assistant.py file. (Here are instructions on manually registering a device and creating a device instance–I don’t know if an instance is required for this to work, but it’s part of what I did trying to solve this).
          Open the assistant.py code and scroll down to line 124. The current call is this:
          In the updated method found on Google’s dev site, it should read:
          with Assistant(credentials, device_model_id) as assistant:
          Where you replace device_model_id with whatever you registered before.
          with Assistant(credentials, "Raddys-magic-mirror-device-id") as assistant:
          Run it and it should work!
          gauravsacc 1 Reply Last reply Reply Quote 0
          • gauravsacc
            gauravsacc Module Developer @Raddy last edited by
            @Raddy said in Possible Issue: MMM-GoogleAssistant with recent Google Assistant SDK update:
            d method f
            just an update. I’ve updated the MMM-GoogleAssistant module to work with the new SDK 🙂
