    MagicMirror Stuck/Freeze
    11 Posts 4 Posters 10.9k Views 2 Watching
    • swvwS
      swvw
      Hi Maybe some one can help with the following bug.
      once I started the Magic mirror V2 beta everything looks good.
      But after a few hours / minutes everything freezes No time update our new compliments the Raspberry PI is completely stuck.
      Nothing works any more I can only remove the power en restart.
      any logging I can enable / check ?
      using Traffic / Drive time, Google Agenda, Dutch RSS for news, weather and compliments
      Raspberry PI 3
      • KirAsh4K
        KirAsh4 Moderator
        Let’s isolate things … can you run the rPi without MM running, just let it sit on the desktop and let it sit for a few hours, see what happens.
        • swvwS
          swvw
          Thanks KirAsh4 for the quick reply :)
          That’s something I have already done.
          Without mm running the PI has no problems and works after coming back to it
          I will try It without some ‘basic’ module settings and check if its something in a specific module.
          • KirAsh4K
            KirAsh4 Moderator
            Can you try running MM with the default sample config that it comes with? Let it sit for a while, see if it freezes then too?
            • MichMichM
              MichMich
              Could you try running your Pi with an other processor intensive task?
              It might be caused by you power supply. Did you try an other one?
              • swvwS
                swvw
                okay have done some tests again running the sample config has no problems its keeps running.
                have treid with only the time. after a few hours its stuck.
                But this time I can alt tab back to the console but it will not termante the MM
                • MichMichM
                  MichMich
                  I know it sounds weird. But can you try an other power source? At least 2A.
                  • KirAsh4K
                    KirAsh4 Moderator
                    Couple of things:
                    • Are you using a proper power supply for the pi? You want something that can provide at least 2Amps.
                    • Is the rPi very hot? Do you have it in a sealed box with little air flow?
                    • Have you checked the file system itself on the card? One method is to issue a forced check upon a reboot with 'sudo shutdown -F -r now' - After the reboot, look the results in '/var/log/fsck/'. If for some reason that fails when you type it in, you can try adding 'fsck.mode=force fsck.repair=yes' to /boot/cmdline.txtand reboot the pi. That will force a file system check upon start up and you can watch to see if there are errors.
                    • Failing that, you can always move all of your modules onto a different computer (or in the cloud somewhere), rebuild the pi from a fresh image, and try it again, see what happens.
                    Reply Quote 1
                    • swvwS
                      swvw
                      okay have been working and testing the Raspberry PI 3
                      Reinstalled a few times checked the SD for corruption / and the temp of the system without any problems…
                      next I checked the Power supply sometimes seeing a orange box in top left corner when it was stuck.
                      With other power supply same problem. after few minutes to a hour is was stuck again
                      I finally found the problem not in MM but running ‘memtester 500m 2’ I found there was I Failure in the memory
                      After going back to the store and getting a replacement PI the problem are fixed.
                      Thanks for the suggestions and maybe this will help some one with the same problems :)
                      Reply Quote 1
                      • F
                        Flance
                        So I’m having the same propped but it different I do have The RPi 3 MB but mine overheard and then everything freezes could that just need a cooler?
                        • F
                          Flance
                          Last thing I see before it crashes https://gyazo.com/b9e8990255cfe865eb0055eb414b05ae
                          Modules alert,holiday,hello world,weather, and (motion detector had a few problems with)
