MagicMirror Stuck/Freeze
11 Posts 4 Posters 9.5k Views 2 Watching
    swvw
    Hi Maybe some one can help with the following bug.
    once I started the Magic mirror V2 beta everything looks good.
    But after a few hours / minutes everything freezes No time update our new compliments the Raspberry PI is completely stuck.
    Nothing works any more I can only remove the power en restart.
    any logging I can enable / check ?
    using Traffic / Drive time, Google Agenda, Dutch RSS for news, weather and compliments
    Raspberry PI 3
    • K Offline
      KirAsh4 Moderator
      Let’s isolate things … can you run the rPi without MM running, just let it sit on the desktop and let it sit for a few hours, see what happens.
        swvw
        Thanks KirAsh4 for the quick reply :)
        That’s something I have already done.
        Without mm running the PI has no problems and works after coming back to it
        I will try It without some ‘basic’ module settings and check if its something in a specific module.
        • K Offline
          KirAsh4 Moderator
          Can you try running MM with the default sample config that it comes with? Let it sit for a while, see if it freezes then too?
            MichMich Admin
            Could you try running your Pi with an other processor intensive task?
            It might be caused by you power supply. Did you try an other one?
              swvw
              okay have done some tests again running the sample config has no problems its keeps running.
              have treid with only the time. after a few hours its stuck.
              But this time I can alt tab back to the console but it will not termante the MM
                MichMich Admin
                I know it sounds weird. But can you try an other power source? At least 2A.
                • K Offline
                  KirAsh4 Moderator
                  Couple of things:
                  • Are you using a proper power supply for the pi? You want something that can provide at least 2Amps.
                  • Is the rPi very hot? Do you have it in a sealed box with little air flow?
                  • Have you checked the file system itself on the card? One method is to issue a forced check upon a reboot with 'sudo shutdown -F -r now' - After the reboot, look the results in '/var/log/fsck/'. If for some reason that fails when you type it in, you can try adding 'fsck.mode=force fsck.repair=yes' to /boot/cmdline.txtand reboot the pi. That will force a file system check upon start up and you can watch to see if there are errors.
                  • Failing that, you can always move all of your modules onto a different computer (or in the cloud somewhere), rebuild the pi from a fresh image, and try it again, see what happens.
                    swvw
                    okay have been working and testing the Raspberry PI 3
                    Reinstalled a few times checked the SD for corruption / and the temp of the system without any problems…
                    next I checked the Power supply sometimes seeing a orange box in top left corner when it was stuck.
                    With other power supply same problem. after few minutes to a hour is was stuck again
                    I finally found the problem not in MM but running ‘memtester 500m 2’ I found there was I Failure in the memory
                    After going back to the store and getting a replacement PI the problem are fixed.
                    Thanks for the suggestions and maybe this will help some one with the same problems :)
                    • F Offline
                      Flance
                      So I’m having the same propped but it different I do have The RPi 3 MB but mine overheard and then everything freezes could that just need a cooler?
