    MagicMirror Stuck/Freeze
    11 Posts 4 Posters 9.8k Views 2 Watching
    • KirAsh4K Offline
      KirAsh4 Moderator
      Can you try running MM with the default sample config that it comes with? Let it sit for a while, see if it freezes then too?
      • MichMichM Offline
        MichMich
        Could you try running your Pi with an other processor intensive task?
        It might be caused by you power supply. Did you try an other one?
        • swvwS Offline
          swvw
          okay have done some tests again running the sample config has no problems its keeps running.
          have treid with only the time. after a few hours its stuck.
          But this time I can alt tab back to the console but it will not termante the MM
          • MichMichM Offline
            MichMich
            I know it sounds weird. But can you try an other power source? At least 2A.
            • KirAsh4K Offline
              KirAsh4 Moderator
              Couple of things:
              • Are you using a proper power supply for the pi? You want something that can provide at least 2Amps.
              • Is the rPi very hot? Do you have it in a sealed box with little air flow?
              • Have you checked the file system itself on the card? One method is to issue a forced check upon a reboot with 'sudo shutdown -F -r now' - After the reboot, look the results in '/var/log/fsck/'. If for some reason that fails when you type it in, you can try adding 'fsck.mode=force fsck.repair=yes' to /boot/cmdline.txtand reboot the pi. That will force a file system check upon start up and you can watch to see if there are errors.
              • Failing that, you can always move all of your modules onto a different computer (or in the cloud somewhere), rebuild the pi from a fresh image, and try it again, see what happens.
              • swvwS Offline
                swvw
                okay have been working and testing the Raspberry PI 3
                Reinstalled a few times checked the SD for corruption / and the temp of the system without any problems…
                next I checked the Power supply sometimes seeing a orange box in top left corner when it was stuck.
                With other power supply same problem. after few minutes to a hour is was stuck again
                I finally found the problem not in MM but running ‘memtester 500m 2’ I found there was I Failure in the memory
                After going back to the store and getting a replacement PI the problem are fixed.
                Thanks for the suggestions and maybe this will help some one with the same problems :)
                • F Offline
                  Flance
                  So I’m having the same propped but it different I do have The RPi 3 MB but mine overheard and then everything freezes could that just need a cooler?
                  • F Offline
                    Flance
                    Last thing I see before it crashes https://gyazo.com/b9e8990255cfe865eb0055eb414b05ae
                    Modules alert,holiday,hello world,weather, and (motion detector had a few problems with)
