    Need some advise. Digital Ocean Modules
    19 Posts 2 Posters 11.4k Views 2 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @andrewchumchal
      @andrewchumchal
      for(var i = 0; i < this.droplets.droplets.length; i++;){
          var name = this.droplets.droplets[i].name;
          var status = this.droplets.droplets[i].status;
          var ip = '';
          for(var n = 0; n < this.droplets.droplets[i].networks['v4'].length; n++;){
              ip += this.droplets.droplets[i].networks['v4'].ip_address + ' | ';
          for(var n = 0; n < this.droplets.droplets[i].networks['v6'].length; n++;){
              ip += this.droplets.droplets[i].networks['v6'].ip_address + ' | ';
          ip = ip.replace(/ | $/, '');
      andrewchumchalA 1 Reply Last reply Reply Quote 0
      • andrewchumchalA Offline
        andrewchumchal @strawberry 3.141
        @strawberry-3.141
        sorry to bug you so much dose that go in the get dom ?
          @andrewchumchal this is just how you can access status name and the ip in getDom for example but you still need to render this
            andrewchumchal
            This post is deleted!
              andrewchumchal
              @strawberry-3-141 Hey. I was not able to get it to display it last night. I try everything i could. Any more ideas ?
                @andrewchumchal
                getDom: function() {
                    if(this.droplets){
                        var table = document.createElement("table");
                        for(var i = 0; i < this.droplets.droplets.length; i++){
                            var row = document.createElement("tr");
                            var name = document.createElement("td");
                            name.innerHTML = this.droplets.droplets[i].name;
                            row.appendChild(name);
                            var status = document.createElement("td");
                            status.innerHTML = this.droplets.droplets[i].status;
                            row.appendChild(status);
                            var ips = '';
                                ips += this.droplets.droplets[i].networks['v4'][n].ip_address + ' | ';
                                ips += this.droplets.droplets[i].networks['v6'][n].ip_address + ' | ';
                            ips = ips.replace(/ | $/, '');
                            var ip = document.createElement("td");
                            ip.innerHTML = ips;
                            row.appendChild(ip);
                            table.appendChild(row);
                        wrapper.appendChild(table);
                    } else {
                        wrapper.innerHTML = "No data to show!";
                    return wrapper;
                  @strawberry-3.141
                  I just update my code.
                  And i have a droplet created but it shows no data to show ?
                    @andrewchumchal this is all untested and should give you just a direction on how it could be solved. make sure you update the dom when receiving data
                    socketNotificationReceived: function(notification, payload){
                        if(notification === "DATA"){
                           this.droplets = payload;
                           this.updateDom();
                      andrewchumchal
                      Thanks you so much @strawberry-3-141.
