    Need some advise. Digital Ocean Modules
    19 Posts 2 Posters 12.6k Views 2 Watching
    • strawberry 3.141S Offline
      can you show what you’ve got so far and what you want to use from the api (e.g. which methods) ?
        andrewchumchal @strawberry 3.141
        @strawberry-3.141 I would like to pull the IP and Name and the Status. and here is a copy of my MMM-Digital-Ocean.js file https://raw.githubusercontent.com/andyipod1437/MMM-Digital-Ocean/master/MMM-Digital-Ocean.js
          this should give you a litte help
          node_helper.js
          const DIGITALOCEAN = require('dropletapi').Droplets;
          const NodeHelper = require('node_helper');
              digitalocean: null,
              start: function() {
                  console.log("Starting module: " + this.name);
                  if (notification === "CONFIG") {
                      this.config = payload;
                      this.digitalocean = new DIGITALOCEAN(this.config.api_key);
                      setInterval(() => {
                          this.getData();
                      }, this.config.updateInterval);
                      this.getData();
              getData: function() {
                  this.digitalocean.listDroplets((error, result) => {
                      if (error) {
                          console.log(error);
                      } else {
                          this.sendSocketNotification("DATA", result);
          MMM-Digital-Ocean.js in start method
          this.sendSocketNotification("CONFIG", this.config);
          in socketNotificationReceived
          if(notification === "DATA"){
              this.droplets = payload;
          in getDom you can iterate over all droplets and build the output you want
            @strawberry-3.141
            where do i add the very last part ?
              strawberry 3.141 Project Sponsor Module Developer @andrewchumchal
              @andrewchumchal also in MMM-Digital-Ocean.js
                @strawberry-3.141
                Any where ? or in a function called socketNotificationReceived
                  @andrewchumchal
                  socketNotificationReceived: function(notification, payload){
                  A 2 Replies Last reply Reply Quote 0
                    @strawberry-3.141
                    Thanks again for all of you help. Now I just need to get the getDom to work :)
                      @strawberry-3.141
                      Any ideas where i can start? like where i can get the name and status.
                        @andrewchumchal
                        for(var i = 0; i < this.droplets.droplets.length; i++;){
                            var name = this.droplets.droplets[i].name;
                            var status = this.droplets.droplets[i].status;
                            var ip = '';
                            for(var n = 0; n < this.droplets.droplets[i].networks['v4'].length; n++;){
                                ip += this.droplets.droplets[i].networks['v4'].ip_address + ' | ';
                            for(var n = 0; n < this.droplets.droplets[i].networks['v6'].length; n++;){
                                ip += this.droplets.droplets[i].networks['v6'].ip_address + ' | ';
                            ip = ip.replace(/ | $/, '');
                          @strawberry-3.141
                          sorry to bug you so much dose that go in the get dom ?
                            @andrewchumchal this is just how you can access status name and the ip in getDom for example but you still need to render this
                              andrewchumchal
                                andrewchumchal
                                @strawberry-3-141 Hey. I was not able to get it to display it last night. I try everything i could. Any more ideas ?
                                  @andrewchumchal
                                  getDom: function() {
                                      if(this.droplets){
                                          var table = document.createElement("table");
                                          for(var i = 0; i < this.droplets.droplets.length; i++){
                                              var row = document.createElement("tr");
                                              var name = document.createElement("td");
                                              name.innerHTML = this.droplets.droplets[i].name;
                                              row.appendChild(name);
                                              var status = document.createElement("td");
                                              status.innerHTML = this.droplets.droplets[i].status;
                                              row.appendChild(status);
                                              var ips = '';
                                                  ips += this.droplets.droplets[i].networks['v4'][n].ip_address + ' | ';
                                                  ips += this.droplets.droplets[i].networks['v6'][n].ip_address + ' | ';
                                              ips = ips.replace(/ | $/, '');
                                              var ip = document.createElement("td");
                                              ip.innerHTML = ips;
                                              row.appendChild(ip);
                                              table.appendChild(row);
                                          wrapper.appendChild(table);
                                      } else {
                                          wrapper.innerHTML = "No data to show!";
                                      return wrapper;
                                    @strawberry-3.141
                                    I just update my code.
                                    And i have a droplet created but it shows no data to show ?
                                      @andrewchumchal this is all untested and should give you just a direction on how it could be solved. make sure you update the dom when receiving data
                                             this.updateDom();
                                        andrewchumchal
                                        Thanks you so much @strawberry-3-141.
