    not realy Fullscreen
    3 Posts 3 Posters 4.9k Views 3 Watching
      bjoern
      when i start the raspberry and later MagicMirror i don’t have a fullscreen view. look at the pircture please. What can i do? 0_1473418102035_IMG_5327.JPG 0_1473418191224_IMG_5326.JPG
      • O Offline
        ostfilinchen
        Du kannst im Desktop auf Einstellungen -> Raspberry-PI-Konfiguration gehen. Dort dann die Übertastung auf deaktiviert setzen. Eventuell muss der RPi neugestartet werden.
        Moderator’s note: While some folks here read German, not everyone does. Posting in English is preferred. That said, pardon the translation, but it’s what Google Translate comes up with:
        “You can browse the Desktop Preferences - Go> Raspberry PI configuration. There then set the overscan on disabled. Possibly the Rpi must be restarted.”
        • Y Offline
          yawns Moderator
          Open the configuration file (in bash type sudo nano /boot/config.txt) and look for disable_overscan
          This is either commented with a # or set to 0
          It should be disable-overscan=1
          Be sure to look through the whole file, sometimes this setting appears more than once.
          Reboot your pi and you should be good
          1 Reply Last reply Reply Quote 4
