    MMM-Podcast don't show/load the latest video
    16 Posts 5 Posters 9.8k Views 5 Watching
    • cruunnerrC Offline
      cruunnerr
      Re: MMM-Podcast dont´t show the latest video
      Hey,
      i installed the MMM-Podcast module and it works as it should. I can send a notification or simply press a button, and the video starts playing. Unfortunately its the same video since 3 days. I use the default feedURL (Tagesschau in 100 sek.)
      I looked into the Podcast folder with an ftp-program an it says that the video.mp4 was created today at 05:05 am. But its the same video as 3 days before ?!?!?!
      I looked at the website of this feed, and there are still newer videos. Maybe someone got the same problem or an idea and can help.
      this morning i typed “pm2 flush”.
      this evening i checked pm2 logs and it says:
      TypeError: this.socketNotificationReceived is not a function
          at Timeout._onTimeout (/home/pi/MagicMirror/modules/MMM-Podcast/node_helper.js:32:32)
          at tryOnTimeout (timers.js:232:11)
          at Timer.listOnTimeout (timers.js:202:5)
      My config:
                              module: 'MMM-Podcast',
                                      updateVideoHours: 5,
                                      updateVideoMinutes: 5,
                                      feedurl: 'http://www.tagesschau.de/export/video-podcast/webxl/tagesschau-in-100-sekunden/'
      thank you :)
      justjim1220J 1 Reply Last reply Reply Quote 0
        cruunnerr
        Okay… false alarm. Just forget it, it’s working now :D Sorry
          doubleT Module Developer
          No internet connection? ;)
            cruunnerr
            no, but i am new to programming so it was hard for me to find out.
            after i checked the pm2 log again i just gave it a try…
            Because it says “this.socketNotificationReceived is not a function”
            i needed to change a line in the node_helper.js
            default one:
            else if(this.loaded){
                                            omx.play("modules/MMM-Podcast/video.mp4", {audioOutput: 'local'});
                                    else{
                                            setTimeout(function(){this.socketNotificationReceived(notification, payload)},2000);
            i changed line 32 to this:
                                    else{
                                            setTimeout(function(){self.socketNotificationReceived(notification, payload)},2000);
            i think, that the download of the video.mp4 wasn’t set to “finished” from the script, so a new video would never be downloaded.
            Anyhow it works now, but i noticed that the “updateVideoHours” function in the config.js has no effect at all.
            The video has been downloaded several times this day (i think 3-4 times).
            But thats ok for me, as the video file is updated also 3-4 times from the website. :)
              cruunnerr
              ok… i am dumb :(
              i realized that the video only was downloaded a few times, cause my Mirror restarts all the time. The watchdog module recognized a few Heartbeat timeouts and restarts every time.
              So maybe i need to do some troubleshooting first ^^
                Ah, debugging. Welcome to the live of a developer. Good luck.
                • MrCoffeeM Offline
                  MrCoffee
                  I am not sure if I should open a new topic, but somehow it fits here as well.
                  My MMM-Podcast does not show any video at all.
                  I use the default feedURL like shown above.
                  Is it correct that the modul does not show anything on startup or is there a picture of the linked video shown?
                  I do not have MMM-Button installed, but it should work with “http://IP:8080/remote?action=NOTIFICATION& notification=BUTTON_PRESSED” as well.
                  Sending the command my browser says “success” but nothing happens. It always shows nothing.
                  Can anyone help?
                  Thank you.
                  Mr.Coffee
                  • F Offline
                    fox @MrCoffee
                    @MrCoffee
                    Did you get it running?
                    Bild Text
                    MrCoffeeM 1 Reply Last reply Reply Quote 0
                    • MrCoffeeM Offline
                      MrCoffee @fox
                      @fox
                      No. Unfortunately not.
                      I don´t know what the issue is. The area were the module should be, is just black.
                      Nothing happens.
                      • F Offline
                        fox @MrCoffee
                        @MrCoffee
                        I tried also to debug this, but my error.log dont give me any information.
                        • MrCoffeeM Offline
                          MrCoffee @fox
                          @fox
                          Thats interessting. I just realized your screenshot above.
                          In my case it does not show anything.
                          Can you please post the part of your config?
                          Where do I find the error.log?
                            cruunnerr
                            did you guys install the omxplayer correctly?
                            check it like this:
                            cd MagicMirror/modules/MMM-Podcast
                            omxplayer -o hdmi video.mp4
                            this should play the video.
                            I am not using a header, so my module isn’t shown on the MM, too. I think that is correct.
                            MrCoffeeM 3 Replies Last reply Reply Quote 0
                            • MrCoffeeM Offline
                              MrCoffee @cruunnerr
                              @cruunnerr
                              Thanks for helping us.
                              I tried the code. The player doesn´t show a video but says “have a nice day” in the command line.
                              I reinstalled it with
                              • sudo apt-get purge omxplayer
                              • sudo apt-get install omxplayer
                              Unfortunately it does not help. It is still “have a nice day”.
                              Any further ideas?
                              • MrCoffeeM Offline
                                MrCoffee @cruunnerr
                                @cruunnerr
                                I just tried another video just to be sure: omxplayer /opt/vc/src/hello_pi/hello_video/test.h264
                                This time it does show some text, but still no video.
                                The text is:
                                Video codec omx-h264 width 1920 height 1080 profile 77 fps 25.000000
                                Subtitle count: 0, state: off, index: 1, delay:0
                                However it does not quit. There is no “have a nice day” but it still shows nothing.
                                • MrCoffeeM Offline
                                  MrCoffee @cruunnerr
                                  @cruunnerr
                                  So after a couple of days I gave it a new try.
                                  You were close to the solution. I did not install the dependencies right.
                                  For all with the same issue, you have to read the instructions better than I did:
                                  1. Navigate into your MagicMirror’s modules folder and execute git clone https://github.com/ptrbld/MMM-Podcast.git. A new folder will appear navigate into it. --> which means navigate into MMM-Podcast.
                                  2. Execute npm install to install the node dependencies. --> in the folder MMM-Podcast, install the omx-manager and omxdirector (see dependencies).
                                    3. Install omxplayer. --> However, I already had the newest version installed.
                                  Now it works fine. And it is pretty awesome.
                                  Thanks for helping me.
                                  Mr.Coffee
                                  • justjim1220J Offline
                                    justjim1220 Module Developer @cruunnerr
                                    This post is deleted!
