    MMM-Podcast don't show/load the latest video
    16 Posts 5 Posters 8.9k Views 5 Watching
      doubleT Module Developer
      No internet connection? ;)
      • cruunnerrC Offline
        cruunnerr
        no, but i am new to programming so it was hard for me to find out.
        after i checked the pm2 log again i just gave it a try…
        Because it says “this.socketNotificationReceived is not a function”
        i needed to change a line in the node_helper.js
        default one:
        else if(this.loaded){
                                        omx.play("modules/MMM-Podcast/video.mp4", {audioOutput: 'local'});
                                else{
                                        setTimeout(function(){this.socketNotificationReceived(notification, payload)},2000);
        i changed line 32 to this:
                                else{
                                        setTimeout(function(){self.socketNotificationReceived(notification, payload)},2000);
        i think, that the download of the video.mp4 wasn’t set to “finished” from the script, so a new video would never be downloaded.
        Anyhow it works now, but i noticed that the “updateVideoHours” function in the config.js has no effect at all.
        The video has been downloaded several times this day (i think 3-4 times).
        But thats ok for me, as the video file is updated also 3-4 times from the website. :)
          cruunnerr
          ok… i am dumb :(
          i realized that the video only was downloaded a few times, cause my Mirror restarts all the time. The watchdog module recognized a few Heartbeat timeouts and restarts every time.
          So maybe i need to do some troubleshooting first ^^
            Ah, debugging. Welcome to the live of a developer. Good luck.
            • MrCoffeeM Offline
              MrCoffee
              I am not sure if I should open a new topic, but somehow it fits here as well.
              My MMM-Podcast does not show any video at all.
              I use the default feedURL like shown above.
              Is it correct that the modul does not show anything on startup or is there a picture of the linked video shown?
              I do not have MMM-Button installed, but it should work with “http://IP:8080/remote?action=NOTIFICATION& notification=BUTTON_PRESSED” as well.
              Sending the command my browser says “success” but nothing happens. It always shows nothing.
              Can anyone help?
              Thank you.
              Mr.Coffee
              foxF 1 Reply Last reply Reply Quote 0
              • foxF Offline
                fox @MrCoffee
                @MrCoffee
                Did you get it running?
                Bild Text
                Issues With MMM-WatchDog known?
                https://forum.magicmirror.builders/post/29827
                Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                MrCoffeeM 1 Reply Last reply Reply Quote 0
                • MrCoffeeM Offline
                  MrCoffee @fox
                  @fox
                  No. Unfortunately not.
                  I don´t know what the issue is. The area were the module should be, is just black.
                  Nothing happens.
                  • foxF Offline
                    fox @MrCoffee
                    @MrCoffee
                    I tried also to debug this, but my error.log dont give me any information.
                    • MrCoffeeM Offline
                      MrCoffee @fox
                      @fox
                      Thats interessting. I just realized your screenshot above.
                      In my case it does not show anything.
                      Can you please post the part of your config?
                      Where do I find the error.log?
                        cruunnerr
                        did you guys install the omxplayer correctly?
                        check it like this:
                        cd MagicMirror/modules/MMM-Podcast
                        omxplayer -o hdmi video.mp4
                        this should play the video.
                        I am not using a header, so my module isn’t shown on the MM, too. I think that is correct.
                        MrCoffeeM 3 Replies Last reply Reply Quote 0
