    MMM-Podcast don't show/load the latest video
    16 Posts 5 Posters 9.7k Views 5 Watching
    • cruunnerrC Offline
      cruunnerr
      ok… i am dumb :(
      i realized that the video only was downloaded a few times, cause my Mirror restarts all the time. The watchdog module recognized a few Heartbeat timeouts and restarts every time.
      So maybe i need to do some troubleshooting first ^^
        doubleT Module Developer
        Ah, debugging. Welcome to the live of a developer. Good luck.
        • MrCoffeeM Offline
          MrCoffee
          I am not sure if I should open a new topic, but somehow it fits here as well.
          My MMM-Podcast does not show any video at all.
          I use the default feedURL like shown above.
          Is it correct that the modul does not show anything on startup or is there a picture of the linked video shown?
          I do not have MMM-Button installed, but it should work with “http://IP:8080/remote?action=NOTIFICATION& notification=BUTTON_PRESSED” as well.
          Sending the command my browser says “success” but nothing happens. It always shows nothing.
          Can anyone help?
          Thank you.
          Mr.Coffee
          • F Offline
            fox @MrCoffee
            @MrCoffee
            Did you get it running?
            Bild Text
            Issues With MMM-WatchDog known?
            https://forum.magicmirror.builders/post/29827
            Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
            MrCoffeeM 1 Reply Last reply Reply Quote 0
            • MrCoffeeM Offline
              MrCoffee @fox
              @fox
              No. Unfortunately not.
              I don´t know what the issue is. The area were the module should be, is just black.
              Nothing happens.
              • F Offline
                fox @MrCoffee
                @MrCoffee
                I tried also to debug this, but my error.log dont give me any information.
                • MrCoffeeM Offline
                  MrCoffee @fox
                  @fox
                  Thats interessting. I just realized your screenshot above.
                  In my case it does not show anything.
                  Can you please post the part of your config?
                  Where do I find the error.log?
                    cruunnerr
                    did you guys install the omxplayer correctly?
                    check it like this:
                    cd MagicMirror/modules/MMM-Podcast
                    omxplayer -o hdmi video.mp4
                    this should play the video.
                    I am not using a header, so my module isn’t shown on the MM, too. I think that is correct.
                    MrCoffeeM 3 Replies Last reply Reply Quote 0
                    • MrCoffeeM Offline
                      MrCoffee @cruunnerr
                      @cruunnerr
                      Thanks for helping us.
                      I tried the code. The player doesn´t show a video but says “have a nice day” in the command line.
                      I reinstalled it with
                      • sudo apt-get purge omxplayer
                      • sudo apt-get install omxplayer
                      Unfortunately it does not help. It is still “have a nice day”.
                      Any further ideas?
                      • MrCoffeeM Offline
                        MrCoffee @cruunnerr
                        @cruunnerr
                        I just tried another video just to be sure: omxplayer /opt/vc/src/hello_pi/hello_video/test.h264
                        This time it does show some text, but still no video.
                        The text is:
                        Video codec omx-h264 width 1920 height 1080 profile 77 fps 25.000000
                        Subtitle count: 0, state: off, index: 1, delay:0
                        However it does not quit. There is no “have a nice day” but it still shows nothing.
                        • MrCoffeeM Offline
                          MrCoffee @cruunnerr
                          @cruunnerr
                          So after a couple of days I gave it a new try.
                          You were close to the solution. I did not install the dependencies right.
                          For all with the same issue, you have to read the instructions better than I did:
                          1. Navigate into your MagicMirror’s modules folder and execute git clone https://github.com/ptrbld/MMM-Podcast.git. A new folder will appear navigate into it. --> which means navigate into MMM-Podcast.
                          2. Execute npm install to install the node dependencies. --> in the folder MMM-Podcast, install the omx-manager and omxdirector (see dependencies).
                            3. Install omxplayer. --> However, I already had the newest version installed.
                          Now it works fine. And it is pretty awesome.
                          Thanks for helping me.
                          Mr.Coffee
                          • justjim1220J Offline
                            justjim1220 Module Developer @cruunnerr
