    MMM-Podcast don't show/load the latest video
    16 Posts 5 Posters 10.0k Views 5 Watching
    • MrCoffeeM
      MrCoffee
      I am not sure if I should open a new topic, but somehow it fits here as well.
      My MMM-Podcast does not show any video at all.
      I use the default feedURL like shown above.
      Is it correct that the modul does not show anything on startup or is there a picture of the linked video shown?
      I do not have MMM-Button installed, but it should work with “http://IP:8080/remote?action=NOTIFICATION& notification=BUTTON_PRESSED” as well.
      Sending the command my browser says “success” but nothing happens. It always shows nothing.
      Can anyone help?
      Thank you.
      Mr.Coffee
      F 1 Reply Last reply
      • F
        fox @MrCoffee
        @MrCoffee
        Did you get it running?
        Bild Text
        Issues With MMM-WatchDog known?
        https://forum.magicmirror.builders/post/29827
        Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
        MrCoffeeM 1 Reply Last reply
        • MrCoffeeM
          MrCoffee @fox
          @fox
          No. Unfortunately not.
          I don´t know what the issue is. The area were the module should be, is just black.
          Nothing happens.
          • F
            fox @MrCoffee
            @MrCoffee
            I tried also to debug this, but my error.log dont give me any information.
            • MrCoffeeM
              MrCoffee @fox
              @fox
              Thats interessting. I just realized your screenshot above.
              In my case it does not show anything.
              Can you please post the part of your config?
              Where do I find the error.log?
              • cruunnerrC
                cruunnerr
                did you guys install the omxplayer correctly?
                check it like this:
                cd MagicMirror/modules/MMM-Podcast
                omxplayer -o hdmi video.mp4
                this should play the video.
                I am not using a header, so my module isn’t shown on the MM, too. I think that is correct.
                MrCoffeeM 3 Replies Last reply
                • MrCoffeeM
                  MrCoffee @cruunnerr
                  @cruunnerr
                  Thanks for helping us.
                  I tried the code. The player doesn´t show a video but says “have a nice day” in the command line.
                  I reinstalled it with
                  • sudo apt-get purge omxplayer
                  • sudo apt-get install omxplayer
                  Unfortunately it does not help. It is still “have a nice day”.
                  Any further ideas?
                  • MrCoffeeM
                    MrCoffee @cruunnerr
                    @cruunnerr
                    I just tried another video just to be sure: omxplayer /opt/vc/src/hello_pi/hello_video/test.h264
                    This time it does show some text, but still no video.
                    The text is:
                    Video codec omx-h264 width 1920 height 1080 profile 77 fps 25.000000
                    Subtitle count: 0, state: off, index: 1, delay:0
                    However it does not quit. There is no “have a nice day” but it still shows nothing.
                    • MrCoffeeM
                      MrCoffee @cruunnerr
                      @cruunnerr
                      So after a couple of days I gave it a new try.
                      You were close to the solution. I did not install the dependencies right.
                      For all with the same issue, you have to read the instructions better than I did:
                      1. Navigate into your MagicMirror’s modules folder and execute git clone https://github.com/ptrbld/MMM-Podcast.git. A new folder will appear navigate into it. --> which means navigate into MMM-Podcast.
                      2. Execute npm install to install the node dependencies. --> in the folder MMM-Podcast, install the omx-manager and omxdirector (see dependencies).
                        3. Install omxplayer. --> However, I already had the newest version installed.
                      Now it works fine. And it is pretty awesome.
                      Thanks for helping me.
                      Mr.Coffee
                      • justjim1220J
                        justjim1220 Module Developer @cruunnerr
