    Mirror turning black after a while
    45 Posts 16 Posters 36.2k Views 15 Watching
    • C Offline
      cyberdie
      @alvinger In my case, the problem started after last MM update.
      R AlvingerA 2 Replies Last reply Reply Quote 0
        retroflex Project Sponsor Module Developer @cyberdie
        @cyberdie said in Mirror turning black after a while:
        Same here. Running the latest ResRobot.
        But I think others have reported the same problem but with a different module.
        • AlvingerA Offline
          Alvinger @cyberdie
          @binog @FredJ @cyberdie @schlachtkreuzer6
          Looking through the unirest dependencies it looks like it relies on express which may or may not make it sus eptible to the issues with electron.
          To resolve this I replaced unirest with node-fetch and pushed the new version of MMM-ResRobot to github.
          To upgrade cd to your MagicMirror directory and run the following commands:
          git pull
          npm remove unirest
          npm install
          Please post results in this thread!
          Hope this resolves the issue.
            retroflex Project Sponsor Module Developer @Alvinger
            @Alvinger Thanks for the quick fix! :)
            My first test…
            1. “top” without ResRobot shows about 1% CPU when idle.
            2. Added ResRobot (old version): “top” shows 100% CPU all the time.
            3. Updated ResRobot, removed unirest, npm install: “top” now shows 1% CPU when idle. Yay!
            Looks good so far. Too early to tell anything about memory leaks, but I will keep my mirror running and check tonight. Currently electron shows 18% mem used (for the 2 electron processes).
              Short lived happiness it seemed… After a few minutes CPU is now back at 100% and memory use increasing. :(
              Also tested after reboot of my Pi3 with the same results.
              This is my config:
              			module: "MMM-ResRobot",
              			header: "",
              				routes: [
              					{from: "740015970", to: "740015568"},
              				updateInterval: 2 * 60 * 1000,	// Update every second minute.
              				maximumEntries: 6,  // Number of departures to show on screen
              				truncateAfter: 5,   // A value > 0 will truncate direction name at first space after  characters. 0 = no truncation
              				apiKey: "*******"  // Your ResRobot apiKey
              AlvingerA 1 Reply Last reply Reply Quote 0
                Binog
                But still, I am not using ResRobot,. and do have the same problem, from time to time,…
                • AlvingerA Offline
                  Alvinger @retroflex
                  @retroflex
                  I will dig up another respberry pi and try it out. My test environment is a dietpi vm which runs on a pc so I wouldn’t expect the cpu load to be representative of the load on the pi.
                  • F Offline
                    FredJ
                    I also dont think the issue is with ResRobot itself. But it is great that you are looking into it @Alvinger
                    • C Offline
                      cyberdie
                      no ResRobot running on my setup. Think the problem is electron itself.
                      AlvingerA 1 Reply Last reply Reply Quote 1
                      • AlvingerA Offline
                        Alvinger @cyberdie
                        I agree with others that the problem is most likely related to Electron and not module-specific but rather related to which module dependencies it has.
                        • 4 / 5
