    Mirror turning black after a while
    45 Posts 16 Posters 40.5k Views 15 Watching
    • cruunnerrC Offline
      cruunnerr
      make two or three per day ;)
      than it goes faster
        retroflex Project Sponsor Module Developer
        Maybe this can be the cause?
        https://github.com/electron/electron/issues/11739
          schlachtkreuzer6 @cruunnerr
          @cruunnerr
          I’m working 🙄 didn’t test anything yet 😅
          • F Offline
            FredJ @retroflex
            @retroflex I also got the same issue. MMM-resrobot or something it depends on looks to be causing this. Has anyone found a workaround? Resrobot is one of the main reasons I have the mirror so not really happy about disableing it.
              @Alvinger Do you know what could be the problem with ResRobot here?
                Alvinger @retroflex
                @retroflex I can’t think of anythong off hand.
                I am running an older version of MM myself so haven’t researched the electron issues.
                Can anyone confirm that the issue started with the new MM version?
                As I am running my magic mirror on an original Pi 1 with 256MB RAM with no issues whatsoever I am a bit surprised that the module should cause this.
                Edit: MMM-ResRobot has but one dependency and that is the unirest module.
                Which version of ResRobot are you running? I did a rewrite to reduce the number of updates w while ago.
                  cyberdie
                  @alvinger In my case, the problem started after last MM update.
                  R A 2 Replies Last reply Reply Quote 0
                    retroflex Project Sponsor Module Developer @cyberdie
                    @cyberdie said in Mirror turning black after a while:
                    Same here. Running the latest ResRobot.
                    But I think others have reported the same problem but with a different module.
                      Alvinger @cyberdie
                      @binog @FredJ @cyberdie @schlachtkreuzer6
                      Looking through the unirest dependencies it looks like it relies on express which may or may not make it sus eptible to the issues with electron.
                      To resolve this I replaced unirest with node-fetch and pushed the new version of MMM-ResRobot to github.
                      To upgrade cd to your MagicMirror directory and run the following commands:
                      git pull
                      npm remove unirest
                      npm install
                      Please post results in this thread!
                      Hope this resolves the issue.
                        retroflex Project Sponsor Module Developer @Alvinger
                        @Alvinger Thanks for the quick fix! :)
                        My first test…
                        1. “top” without ResRobot shows about 1% CPU when idle.
                        2. Added ResRobot (old version): “top” shows 100% CPU all the time.
                        3. Updated ResRobot, removed unirest, npm install: “top” now shows 1% CPU when idle. Yay!
                        Looks good so far. Too early to tell anything about memory leaks, but I will keep my mirror running and check tonight. Currently electron shows 18% mem used (for the 2 electron processes).
                          Short lived happiness it seemed… After a few minutes CPU is now back at 100% and memory use increasing. :(
                          Also tested after reboot of my Pi3 with the same results.
                          This is my config:
                          			module: "MMM-ResRobot",
                          			header: "",
                          				routes: [
                          					{from: "740015970", to: "740015568"},
                          				updateInterval: 2 * 60 * 1000,	// Update every second minute.
                          				maximumEntries: 6,  // Number of departures to show on screen
                          				truncateAfter: 5,   // A value > 0 will truncate direction name at first space after  characters. 0 = no truncation
                          				apiKey: "*******"  // Your ResRobot apiKey
                            Binog
                            But still, I am not using ResRobot,. and do have the same problem, from time to time,…
                              Alvinger @retroflex
                              @retroflex
                              I will dig up another respberry pi and try it out. My test environment is a dietpi vm which runs on a pc so I wouldn’t expect the cpu load to be representative of the load on the pi.
                              • F Offline
                                FredJ
                                I also dont think the issue is with ResRobot itself. But it is great that you are looking into it @Alvinger
                                  cyberdie
                                  no ResRobot running on my setup. Think the problem is electron itself.
                                  A 1 Reply Last reply Reply Quote 1
                                    Alvinger @cyberdie
                                    I agree with others that the problem is most likely related to Electron and not module-specific but rather related to which module dependencies it has.
                                    • T Offline
                                      thejoaovitor
                                      A solution, (not perfect) is to use MMM-WatchDog, it keeps an eye on your UI and quits app in case the UI crashes, combined with the PM2 process manager, MM2 will automaticly restart after a UI failure.
                                      https://github.com/MichMich/MMM-WatchDog
                                      • KuhlemannK Offline
                                        Kuhlemann
                                        The problem still seems to persist also with the newest version of MM. Maybe someone has found a real solution?
                                        I will try out MMM-WatchDog meanwhile.
                                          dazza120 @Kuhlemann
                                          @kuhlemann a cron job is the only way think it seems that it taxes the Pi too much after 8hours or so hence Cron Job every 8hours or so
                                            bachoo786 @dazza120
                                            @dazza120 what are you doing with cron to resolve the issue mate?
                                            • 2 / 3
