    Face Recognition - File can't be opened for writing
    8 Posts 4 Posters 15.2k Views 3 Watching
    • F
      feuerball
      Well the Mirror and the modules are working for now.
      The next step is to seperate modules to specific users so i use the FaceRec lib.
      I trained 10 images first for a quick test.
      When im trying to start MMv2 with this module he pushes this error message:
      [MMM-Facial-Recognition] Facerecognition started...
      [MMM-Facial-Recognition] Loading training data...
      [MMM-Facial-Recognition] ALGORITHM: LBPH
      { [Error: OpenCV Error: Unspecified error (File can't be opened for writing!) in load, file /build/opencv-ISmtkH/opencv-2.4.9.1+dfsg/modules/contrib/src/facerec.cpp, line 325
      Traceback (most recent call last):
        File "modules/MMM-Facial-Recognition/facerecognition/facerecognition.py", line 59, in <module>
          model.load(json.loads(sys.argv[1])["trainingFile"])
      cv2.error: /build/opencv-ISmtkH/opencv-2.4.9.1+dfsg/modules/contrib/src/facerec.cpp:325: error: (-2) File can't be opened for writing! in function load
        executable: 'python',
        options: null,
        script: 'modules/MMM-Facial-Recognition/facerecognition/facerecognition.py',
        args: [ '{"recognitionAlgorithm":1,"lbphThreshold":50,"fisherThreshold":250,"eigenThreshold":3000,"useUSBCam":false,"trainingFile":"~/MagicMirror/modules/MMM-Facial-Recognition/training.xml","interval":1,"logoutDelay":15,"users":["Marvin"],"defaultClass":"default","forAllClass":"for_all"}' ],
        exitCode: 1 }
      • K
        KirAsh4 Moderator
        Looks like it doesn’t have permission to open your trainingFile:
        model.load(json.loads(sys.argv[1])[“trainingFile”])
        cv2.error: /build/opencv-ISmtkH/opencv-2.4.9.1+dfsg/modules/contrib/src/facerec.cpp:325: error: (-2) File can’t be opened for writing! in function load
        Notice the File can't be opened for writing message.
        Wherever it’s trying to create that file, the main process running MM can’t write to that location.
        • P
          paviro
          Probably it does not even exist in that path. Be sure to add the training file path to the conduct of put it in the module folder.
          – The Doctor
          • F
            feuerball
            The XML file is located in the module path mmm-facial-recognition.
            I will answer more precisely when I’m back hat home
            • F
              feuerball
              So, my internet is back after a day :D
              I reinstalled the module with deleting & cloning it again.
              The training.xml is located in
              /home/pi/MagicMirror/modules/MMM-Facial-Recognition
              I installed open cv with
              sudo apt-get install libopencv-dev python-opencv
              after this, i went into the folder
              and typed
              sudo npm install
              I still get the same error MSG :(
              i also changed the rights on the training.xml to Anyone/Anyone/Anyone
              please help <3
              • P
                paviro @feuerball
                @feuerball try putting it somewhere else and set the trainingFile setting in your config :)
                – The Doctor
                • F
                  feuerball
                  well i rewrote the destination of the file @ the config again and now it works.
                  seems like there was an error anywhere :D
                  • P
                    pgb168 @feuerball
                    @feuerball I didn’t understand what is the config
                    I am having the same error
