    MMM-WienerLinien
    wienviennapublic transportöpnvwienerlinien
    16 Posts 4 Posters 12.4k Views 4 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @spedja
      @spedja nice timing :) I received my API token this afternoon, will look into this the next days and hopefully can get around the metro problem
        @spedja I couldn’t find any information about this in the documentation, but with further investigation I stumbled on this http://www.offene-oeffis.at/faqs/warum-erhalte-ich-manchmal-etwas-wie-u1-leopoldau-in-x-minuten-als-string-in-towards-statt-als-departure/, so i guess in your screenshot is the departure of the metro in 2 and 5 mins, if so i have to handle those special
        EDIT: should be fixed now
        [card:fewieden/MMM-WienerLinien]
          spedja @strawberry 3.141
          @strawberry-3.141 Yes it works! You are the man! Thank you.
            Beryllium30
            Is it possible to show routes between two stations? I can’t find anything in the documentation.
            Really appreciate the module!
              Dom1n1c
              There is another API available.
              Why don’t you use the EFA (From Elektronische Fahrplanauskunft)
              It’s the biggest Provider in the market (Mentz Datenverarbeitung)
              It includes realtime information and shows routes:
              http://data.wien.gv.at/pdf/wiener-linien-routing.pdf
              It is available for several transportation companies/communities in Germany, UK and so on.
                strawberry 3.141 Project Sponsor Module Developer @Dom1n1c
                @Dom1n1c I didn’t make a research for available API’s, I just took the one I got from the user who requested the module.
                  Two new config options to limit size of the station and destination name
                    Beryllium30
                    Anyone else have it stuck at loading?
                      Changelog:
                      • it is now possible to get informed about elevator and line incidents thanks to @flo80 for his contribution
                        Version 2 is released
                        • API key no longer required
                        • Fix Config option incidentShort.
                        • Dependency updates
                        • Nunjuck templates
                        • and more …
                        How to update
                        Make sure you run cd ~/MagicMirror/modules/MMM-WienerLinien ; git pull ; npm i --production, as I replaced dependencies.
                        https://github.com/fewieden/MMM-WienerLinien
