Need Guidence, Or Someone To Make A Module For Me, Uses GPIO
Hello All!
My name is Anthony, AKA Spicy Jelly. I am a High School Student in the US, with little knowledge in Python, C+, and JavaScript. My idea for a module was displaying a local image as a background. I know this has already been done, but I wanted to put my own twist on it. My plan was to use a Piezo element, as a input for vibrations, from me knocking on the wall, using the RPi’s GPIO pins. When the element detected a vibration input, the local image background would fade, and the mirror would reappear. I would want the other elements to be displayed when both background, and mirror.
~ I have no clue where to start, so if someone would be interested in making this for me, or guiding me in making it, it would be greatly appreciated
- Feel free to contact me
Thank you in advance
-Anthony
@SpicyCoding It’s not nearly as much fun if someone makes it for you.
This might get you started: https://www.youtube.com/watch?v=0PAl340SCAY
Once you can successfully detect a vibration/knock in your Python script, it should be pretty easy to use that code in a node_helper.js to send messages to an image module.
For the coding part, you might consider using CSS to create your transparency:
.module .knockknock { background: url("img_tree.jpg") no-repeat fixed center; opacity: 1.0; }Then for each knock, it could then increment
opacityby0.1. If you wanted to keep the other modules visible, you can position a separate element over the other modules. You could then have a timer running that afterXamount of time theopacityresets to1.0. (Or you can increment theopacityof thebodyand reset theopacityof all child elements/modules to1.0.)You can also get fancier and use CSS animations to create transitions between each step, and to make it reappear, but best to get a proof-of-concept first.
Maybe you saw this thread. I made a module for duedahlb that shows a full size image when the module MMM-Button registers a button press. I think that could be a good start to study and maybe reverse engineer some parts from both modules.
