    Multiple screens fo MM.
    36 Posts 13 Posters 22.5k Views 15 Watching
      sdetweil @chichi1887
      @chichi1887 see this from the doc
      • C Offline
        chichi1887 @sdetweil
        thx so much, both starts, only problem both start at the same Screen and i can’t change the position or start screen. Must change the Display from 0 to 1 oder in the mm.sh config?
          @chichi1887 yes , Linux treats the two monitors as one big display, so you have to add
          electronOptions:{ left:xxxx}
          above the modules:[] list
          to one of the config.js to move the second mm over one screen width size
          if vertical, then it’s y:xxxx
          BKeyportB C 2 Replies Last reply Reply Quote 0
          • BKeyportB Offline
            @sdetweil said in Multiple screens fo MM.:
            Live example - I use two 1920x1080 monitors, my system is using latest OS, but with X11 turned on rather than Wayland for compatibility reasons to some background tasks:
            var config = {
            	address: "0.0.0.0",
            	port: 8081,
            	electronOptions: { x: 1920 },  // Right here!
            	ipWhitelist: [],
            	language: "en",
            	timeFormat: 12,
            	units: "imperial",
            	customCss: "css/custom2.css",
            • C Offline
              @sdetweil thx u so much. All Modules and configs works Perfect. thx
                @chichi1887 awesome. thanks for the feedback
                • 4 / 4
