    Multiple screens fo MM.
    36 Posts 13 Posters 28.6k Views 15 Watching
    • C Offline
      cburchett @sdetweil
      @sdetweil: can you please share an example? I am not sure how to indicate the secondary display in the config files. Thank you!
        sdetweil @cburchett
        @cburchett it’s one big display, so you have to tell it how far from the left edge to start this display.
        see
        https://forum.magicmirror.builders/topic/6623/multiple-screens-fo-mm/18?_=1666468889775
        only need x for horizontal monitors
        or y for vertical
        • C Offline
          cburchett @sdetweil
          @sdetweil Perfect! Thank you.
            Sagar73594 @sdetweil
            @sdetweil said in Multiple screens fo MM.:
            MM_CONFIG=config1.js
            Can you please elaborate, a little bit more? I’m trying this, but not understood well.
            Thank You.
              sdetweil @Sagar73594
              @Sagar73594 if you have a bash or sh script, you can set environment variables that the MM code will read
              export MM_CONFIG=??? filename
              will cause filename to be used as the name of the file to read for configuration (replacing config.js)
              if you use my install script and selected use pm2, then the script is
              ~/MagicMirror/installers/mm.sh
              before the line
              npm start
              add the line above to set the file name
              so, by using different config files, one could launch multiple instances of MagicMirror from the same set of files.
              some could target one display and others another, and some could be server only as weill.
              one could also install 50 modules and use the same 25 in all instances and some mix of the others in different instances, all from the same set of files in the MagicMirror folder tree.
              C 2 Replies Last reply Reply Quote 0
              • C Offline
                chichi1887 @sdetweil
                before the line
                npm start
                • C Offline
                  before the line
                  npm start
                  Hi Sagar,
                  Hello Sagar, thank you for your guidance. Unfortunately, I keep encountering an error upon startup. A version starts automatically with the familiar error message “npm run config: check”. I stop the MagicMirror and manually start it from the MagicMirror folder with npm start, but then it allegedly cannot find the config. As you described, I created config1 and config2, then edited installers/mm.sh and mm2.sh. It looks something like this now:
                  cd ~/MagicMirror
                  export MM_CONFIG=config2.js
                  DISPLAY=:2 npm start
                  I also copied the pm2_MagicMirros.json once and simply appended a “1” to the name. The configuration looks like this:
                  “apps” : [{
                  “name” : “MagicMirror”,
                  “script” : “/home/pi/MagicMirror/installers/mm.sh”,
                  “watch” : [“/home/pi/MagicMirror/config/config1.js”]
                  Do you perhaps have any tips for me on what I might be doing wrong?
                    sdetweil @chichi1887
                    @chichi1887 well, you need two pm2_MagcMirror.json, right? and each points to a different mm.sh, right?
                    original
                    pm2_MagicMirror.json
                    "apps" : [{
                    "name" : "MM_Screen1",
                    "script" : "/home/pi/MagicMirror/installers/mm.sh",
                    "watch" : ["/home/pi/MagicMirror/config/config.js"]
                    new pm2_MagicMirror2.json
                    "apps" : [{
                    "name" : "MM_Screen2",
                    "script" : "/home/pi/MagicMirror/installers/mm2.sh",
                    "watch" : ["/home/pi/MagicMirror/config/config2.js"]
                    then
                    pm2 start each json
                    and then pm2 save
                    to test before pm2 start , you can
                    cd ~/MagicMirror
                    installers/mm2.sh
                    or
                    cd ~/MagicMirror
                    installers/mm.sh
                    to start them both, open another terminal window or ssh session, starting one in each
                    ctrl-c in the term window will end that instance
                    • C Offline
                      cd ~/MagicMirror
                      installers/mm2.sh
                      Hey,
                      the mm.sh starts without a problem but the second has this
                      all modules that starts on the mm.sh are disable in the mm2 config.
                      Display=0 in both are correkt or the second must be nr.1?
                      • C Offline
                        chichi1887 @chichi1887
                        When I start the mm2.sh script, despite the correct configuration, it takes the config.js instead of the config2.js. Therefore, it seems unable to start both instances simultaneously because it attempts to open the same config.js. The configuration looks like this in the mm2.sh script:
                        cd ~/MagicMirror
                        DISPLAY=:0 npm start
                        the pm2_MagicMirror2.json is copy and paste from u ;-)
                          @chichi1887 see this from the doc
                          • C Offline
                            thx so much, both starts, only problem both start at the same Screen and i can’t change the position or start screen. Must change the Display from 0 to 1 oder in the mm.sh config?
                              @chichi1887 yes , Linux treats the two monitors as one big display, so you have to add
                              electronOptions:{ left:xxxx}
                              above the modules:[] list
                              to one of the config.js to move the second mm over one screen width size
                              if vertical, then it’s y:xxxx
                              BKeyportB C 2 Replies Last reply Reply Quote 0
                              • BKeyportB Offline
                                Live example - I use two 1920x1080 monitors, my system is using latest OS, but with X11 turned on rather than Wayland for compatibility reasons to some background tasks:
                                var config = {
                                	address: "0.0.0.0",
                                	port: 8081,
                                	electronOptions: { x: 1920 },  // Right here!
                                	ipWhitelist: [],
                                	language: "en",
                                	timeFormat: 12,
                                	units: "imperial",
                                	customCss: "css/custom2.css",
                                • C Offline
                                  @sdetweil thx u so much. All Modules and configs works Perfect. thx
                                    @chichi1887 awesome. thanks for the feedback
