    Newbe help please
    5 Posts 3 Posters 2.4k Views 3 Watching
    • M
      morso
      Hello,
      It looks like my MagicMirror is running (see below) but the MagiciMirror screen doesn’t start.
      pi@raspberrypi:~/MagicMirror $ pm2 restart  MagicMirror
      Use --update-env to update environment variables
      [PM2] Applying action restartProcessId on app [MagicMirror](ids: 0)
      [PM2] [MagicMirror](0) ✓
      │ Name        │ mode │ status │ ↺   │ cpu │ memory    │
      │ MagicMirror │ fork │ online │ 159 │ 66% │ 11.2 MB   │
       Use `pm2 show ` to get more details about an app
      Everything was working fine from the original install (I even added a module w/o issues) till I followed the instructions to Disabling the screensaver and Disable WiFi Power Save.
      Since I have a RPi 3 (Raspbian Stretch) I used the following instruction:
      For RPi 3 (Raspbian Stretch)
      We no longer have any default entries in /etc/network/interfaces, instead we make a plugin to the (service) startup script. Copy paste the following into you terminal:
      cat << EOF | sudo tee /etc/network/if-up.d/off-power-manager
      > #!/bin/sh
      > # off-power-manager - Disable the internal power manager of the (built-in) wlan0 device
      > # Added by MagicMirrorSetup
      > iw dev wlan0 set power_save off
      > EOF
      #!/bin/sh
      Then set the permissions and reload the network daemon.
      sudo chmod 755 /etc/network/if-up.d/off-power-manager
      sudo /etc/init.d/networking restart
      You don’t need to reboot for this to take effect, but do it anyway to make sure it works. After reboot and your wifi is back up, test with:
      iw dev wlan0 get power_save
      After this the MagicMirror stopped starting up when
      pm2 star MagicMirror
      is executed.
      Any help you could offer to troubleshoot this is much much appreciated.
      Thanks,
      • yawnsY
        yawns Moderator
        Is there a screen connected to the pi? What is it showing?
        Are you working directly on the pi, are you connecting via VNC or are you sshing to the pi?
        If you run pm2 stop MagicMirror and then try npm start inside MagicMirror folder (if directly on the pi) or DISPLAY=:0 nohup npm start & (if connected via ssh), do you see the MagicMirror?
        M 1 Reply Last reply
        • M
          morso @yawns
          @yawns Thanks for the prompt replay. Yes HDMI screen is connected and shows Pi OS desktop.
          I am connected via VNC but I can also work directly on the Pi. Not really sure how to use SSH yet.
          I run
          inside the MM folder from VNC and MagicMirror screen started!!
          I also run
          npm start
          from Pi and works.
          MagicMirror doesn’t start on reboot though. Reboot goes strait to desktop.
          I guess my confusion is that before I just exec
          pm2 start MagicMirror"
          and the MagicMirro screen start while now I will need to run
          npm start
          Can you please explain why this happens and how I can have MagicMirror starts at boot again?
          Thanks so much for your help.
          E 1 Reply Last reply
          • E
            E3V3A @morso
            @morso IDK how old is your MM that was working, but now you need to go to: ~/MagicMirror/installers/ and run the mm.sh script with pm2. I use an alias for this:
            alias mm2='cd $HOME/MagicMirror/installers/; pm2 flush; pm2 start mm.sh && cd $OLDPWD'
            with:
            $ cat ~/MagicMirror/installers/mm.sh
            cd ~/MagicMirror
            DISPLAY=:0 npm start
            “Everything I do (here) is for free – altruism is the way!”
            MMM-FlightsAbove, MMM-Tabulator, MMM-Assistant (co-maintainer)
            • M
              morso @E3V3A
              @E3V3A Thank you very much!!
