    MM docker container problem with mac and linux
    14 Posts 3 Posters 9.2k Views 3 Watching
    • T
      tomasz2101
      Hi i have problem with magic mirror. I started it inside docker container on rpi the MM is working ok. When i try to use docker container on mac or linux there will be no errors but also there will be no MM page under url.
      docker-compose up logs
      docker-compose up
      Starting blackmirror ... done
      Attaching to blackmirror
      blackmirror     | Starting MagicMirror: v2.1.3
      blackmirror     | Loading config ...
      blackmirror     | Loading module helpers ...
      blackmirror     | No helper found for module: alert.
      blackmirror     | Initializing new module helper ...
      blackmirror     | Module helper loaded: updatenotification
      blackmirror     | No helper found for module: clock.
      blackmirror     | All module helpers loaded.
      blackmirror     | Starting server on port 8080 ...
      blackmirror     | You're using a full whitelist configuration to allow for all IPs
      blackmirror     | Server started ...
      blackmirror     | Connecting socket for: updatenotification
      blackmirror     | Sockets connected & modules started ...
      blackmirror     |
      blackmirror     | Ready to go! Please point your browser to: http://localhost:8080
      docker-compose.yaml
      version: '3'
      services:
        magic-mirror:
          image: bastilimbach/docker-magicmirror
          container_name: blackmirror
          restart: always
          volumes:
            - ./config:/opt/magic_mirror/config
            - ./modules:/opt/magic_mirror/modules
          ports:
            - 8082:8080
      config.js
      var config = {
      	address: "localhost",
      	port: 8080,
      	ipWhitelist: [],
      	language: "en",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      R 1 Reply Last reply
      • R
        raywo Module Developer @tomasz2101
        @tomasz2101 Try to set ipWhitelist to [ "127.0.0.1", "::ffff:127.0.0.1", "::1" ]. If you want to access the mirror from your Linux or Mac machine add their respective IPs too.
        • T
          tomasz2101
          @raywo I know that this is strange behaviour of MM and your fix is not according to documentation. I tried that but that fix doesn’t work at all. Additional think is that I’am running container on my mac and i cannot access MM from mac. 192.168.1.176 is my mac local ip. I want to develop new module but i don’t want to do this on rpi.
          var config = {
          	port: 8080,
          	ipWhitelist: [ "127.0.0.1", "::ffff:127.0.0.1", "::1", "192.168.1.176"],
          	language: "en",
          	timeFormat: 24,
          	units: "metric",
          			module: "alert",
          			position: "top_bar"
          			module: "clock",
          • R
            @tomasz2101 Why is that not according to documentation?
            I have a simliar setup like you. I run docker on my mac and access the mirror instance via my mac it works just fine.
            Maybe you should try it without creating your own docker image. Try the solution as described in the MagicMirror documentation.
            • T
              tomasz2101
              @raywo i tried
              docker run  -d \
                                      --publish 8080:8080 \
                                      --restart always \
                                      --volume ~/magic_mirror/config:/opt/magic_mirror/config \
                                      --volume ~/magic_mirror/modules:/opt/magic_mirror/modules \
                                      --name magic_mirror \
              docker ps
              CONTAINER ID        IMAGE                             COMMAND                  CREATED                  STATUS              PORTS                    NAMES
              69efe710da85        bastilimbach/docker-magicmirror   "/opt/magic_mirror/d…"   Less than a second ago   Up 2 seconds        0.0.0.0:8080->8080/tcp   magic_mirror
              docker logs -f magic_mirror
              Loading config ...
              WARNING! Could not find config file. Please create one. Starting with default configuration.
              No helper found for module: helloworld.
              Server started ...
              cat config.js
              var config = {
              	port: 8080,
              	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "192.168.1.176"],
              	language: "en",
              	timeFormat: 24,
              	units: "metric",
              			module: "clock",
              When im trying to access url http://localhost:8080/ in incognito i got always “localhost didn’t send any data” and there is no information in container about trying to access pare.
              • R
                @tomasz2101 This looks okay to me. Although the log states "WARNING! Could not find config file. Please create one. Starting with default configuration.".
                Where did you put your config.js file? Is it in ~/magic_mirror/config on your mac?
                T 1 Reply Last reply
                • T
                  tomasz2101 @raywo
                  @raywo The config.js.sample was created automatically. After that i copy it to config.js and restarted container but logs show:
                  Loading config ...
                  Server started ...
                  • R
                    @tomasz2101 And? Does it work?
                    • T
                      tomasz2101 @raywo
                      @raywo no
                      • R
                        @tomasz2101 In my config.js I put "" in the address setting. I also have "::ffff:192.168.2.1/120" included in my ipWhitelist. My home network is 192.168.2.0.
                        my config.js
                        var config = {
                        	address: "", // - "", "0.0.0.0", "::" to listen on any interface
                        	port: 8080,
                        	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.2.1/120", "192.168.2.110", "172.17.0.1"]
                          /* module config */
                        • T
                          tomasz2101 @raywo
                          @raywo thx a lot now it is working.
                          Also i had to do docker binding to localhost
                          my config:
                          var config = {
                          	address: "",
                          	port: 8080,
                          	ipWhitelist: [],
                          	language: "en",
                          	timeFormat: 24,
                          	units: "metric",
                          			module: "clock",
                          Reply Quote 1
                          • B
                            bastilimbach
                            I updated the Github repository to include a working config file example. Thanks @raywo!
                            Reply Quote 1
                            • R
                              raywo Module Developer @bastilimbach
                              @bastilimbach Good addition to the docs. Thank you!
                              Maybe you should remove "192.168.2.1/120", "192.168.2.110" as it applies only to my configuration. Or you should explain it better.
                              B 1 Reply Last reply
                              • B
                                bastilimbach @raywo
                                @raywo Oh yes you’re absolutely right.
