    Added getHeader function
    1 Posts 1 Posters 1.4k Views 1 Watching
    • MichMichM
      MichMich
      Per request, I’ve added a getHeader() method to the module api. This allows you to modify the header of the module from within the module itself.
      Note: that this method will only be called if the user has set a default header. If not no header will be shown and you won’t be able to update it.
      Note: if you module’s users run an old version of MagicMirror (a version without this change), this method will not be called. No errors should be thrown. So it’s safe to use …
      If you want to use the user’s set header in this method, just reference the this.data.header variable.
      Example code:
      getHeader: function() {
          return this.data.header + '  append string';
      More info:
      • Documentation: https://github.com/MichMich/MagicMirror/tree/develop/modules#getheader
      • Commit: https://github.com/MichMich/MagicMirror/commit/b2a7d3584bad2752d59d2325c581f5018e875306
      Please let me know if this feature works for you …
      Reply Quote 3
