    npm install - electron fails to install
    7 Posts 3 Posters 4.7k Views 3 Watching
      antnorwe
      Hello!
      I’ve been trying all day to get this set up, I’ve uninstalled and reinstalled it so many times already.
      I see the same issue in both the automated and manual methods.
      When running npm install, the electron install fails due to a permission denied error:
      > uws@0.14.5 install /root/MagicMirror/node_modules/uws
      > node-gyp rebuild > build_log.txt 2>&1 || exit 0
      sh: 1: cannot create build_log.txt: Permission denied
      > electron-chromedriver@1.7.1 install /root/MagicMirror/node_modules/spectron/node_modules/electron-chromedriver
      > node ./download-chromedriver.js
      /root/MagicMirror/node_modules/spectron/node_modules/electron-chromedriver/download-chromedriver.js:16
        if (error != null) throw error
      Error: EACCES: permission denied, mkdir '/root/MagicMirror/node_modules/spectron/node_modules/electron-chromedriver/.electron'
      [            ......] - install: info lifecycle electron-chromedriver@1.7.1~install: Failed to exec install script
      But this is on a brand new directory created during the install process, so not sure how I can resolve that?
      I’m running this using the pi user (as I saw in another thread that using the ‘root’ user can cause issues)
      Thanks!
      • Y Offline
        yawns Moderator
        Your cloned MagicMirror folder resides in /root, but it should be /home/pi
        User pi does not have rights to do much in root folder.
        You are logged in as pi, right?
        Try this please
        cd ~
        git clone https://github.com/MichMich/MagicMirror
        cd ~/MagicMirror
        npm install
        npm start
          antnorwe
          Thank you! That worked a treat, and made me feel like a numpty :P
          Hopefully a final issue to resolve before I’m up and running, the automated script seems to have completed all tasks successfully, but when I run npm start the start script fails, and I see this in the debug logs:
          1 verbose cli [ '/usr/bin/node', '/usr/local/bin/npm', 'start', 'debug' ]
          2 info using npm@5.7.1
          3 info using node@v9.8.0
          5 info lifecycle magicmirror@2.2.2~prestart: magicmirror@2.2.2
          6 info lifecycle magicmirror@2.2.2~start: magicmirror@2.2.2
          7 verbose lifecycle magicmirror@2.2.2~start: unsafe-perm in lifecycle true
          8 verbose lifecycle magicmirror@2.2.2~start: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
          9 verbose lifecycle magicmirror@2.2.2~start: CWD: /home/pi/MagicMirror
          10 silly lifecycle magicmirror@2.2.2~start: Args: [ '-c', 'sh run-start.sh "debug"' ]
          11 silly lifecycle magicmirror@2.2.2~start: Returned: code: 1  signal: null
          12 info lifecycle magicmirror@2.2.2~start: Failed to exec start script
          13 verbose stack Error: magicmirror@2.2.2 start: `sh run-start.sh "debug"`
          13 verbose stack Exit status 1
          13 verbose stack     at EventEmitter.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:285:16)
          13 verbose stack     at EventEmitter.emit (events.js:180:13)
          13 verbose stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
          13 verbose stack     at ChildProcess.emit (events.js:180:13)
          13 verbose stack     at maybeClose (internal/child_process.js:936:16)
          13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:220:5)
          14 verbose pkgid magicmirror@2.2.2
          15 verbose cwd /home/pi/MagicMirror
          16 verbose Linux 4.9.35-v7+
          17 verbose argv "/usr/bin/node" "/usr/local/bin/npm" "start" "debug"
          18 verbose node v9.8.0
          19 verbose npm  v5.7.1
          20 error code ELIFECYCLE
          21 error errno 1
          22 error magicmirror@2.2.2 start: `sh run-start.sh "debug"`
          22 error Exit status 1
          23 error Failed at the magicmirror@2.2.2 start script.
          23 error This is probably not a problem with npm. There is likely additional logging output above.
          24 verbose exit [ 1, true ]
          Is this a common error?
            mochman Module Developer
            Are you running it through an SSH connection? If so, try running DISPLAY=:0 nohup npm start &
            If that works, I recommend using pm2 to automatically start your mirror. You can find the guide to get pm2 to work with here.
              antnorwe
              Hey Mochman, I get the same error whether running through SSH or on my Pi directly.
              I tested with your command, and the output of the nohup.out file is:
              > magicmirror@2.2.2 start /home/pi/MagicMirror
              > sh run-start.sh
              npm ERR! code ELIFECYCLE
              npm ERR! errno 1
              npm ERR! magicmirror@2.2.2 start: `sh run-start.sh`
              npm ERR! Exit status 1
              npm ERR!
              npm ERR! Failed at the magicmirror@2.2.2 start script.
              npm ERR!     /home/pi/.npm/_logs/2018-03-11T13_33_02_140Z-debug.log
              Thanks!
                What’s in that logfile that was created?
                  antnorwe
                  Hey, this is the content of the log file:
                  1 verbose cli [ '/usr/bin/node', '/usr/local/bin/npm', 'start' ]
                  10 silly lifecycle magicmirror@2.2.2~start: Args: [ '-c', 'sh run-start.sh' ]
                  13 verbose stack Error: magicmirror@2.2.2 start: `sh run-start.sh`
                  13 verbose stack     at EventEmitter. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:285:16)
                  13 verbose stack     at ChildProcess. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                  21 error errno 1
                  22 error magicmirror@2.2.2 start: `sh run-start.sh`
