    Best way to get two modules in same div ( region, position)?
    2 Posts 2 Posters 2.8k Views 2 Watching
      roro7878
      I have all the modules that I want up and running. I am trying to figure out how to get 2 modules positioned how I would like. For example. I am using the nest module. I have two nests so I am calling them individually in the config. I am not sure if that is the correct way or not. If not please let me know.
      They both show up, but they display vertically ( one on top of the other). I would like them to show up next to each other.
      Is that the css of the position /region or the actual module css or the main css that is causing that to happen?
      I have tried every position btw
      Config Code below
      			"module": "MMM-MyNest",
      			"position": "bottom_bar",
      			"config": {
      				"token": " my actual token",
      				"thermNum": 1,
      				"protectNum": 1,
      				displayName: true, //Display the thermostat name
      			displayType: "nest" //Choose either the Nest display or a list
      			"config": {
      				"token": "my actual token",
      				"thermNum": 2,
      				"protectNum": 1,
        j.e.f.f Project Sponsor Module Developer @roro7878
        @roro7878 Take a look at this thread:
        https://forum.magicmirror.builders/topic/6746/how-to-get-2-modules-side-by-side
