    gauge.js
    16 Posts 3 Posters 7.4k Views 3 Watching
      sispheor
      Hello guys, I’m trying to make working the gauge.js lib on my MM.
      Nothing appears on the screen. No error in logs or the console.
      Here is what I do, I just copied the content of the example available here.
      getScripts: function() {
              return ["http://bernii.github.io/gauge.js/dist/gauge.min.js"];
       getDom: function () {
              let wrapper = document.createElement("div");
              // add a gauge
              let opts = {
                angle: 0.15, /// The span of the gauge arc
                lineWidth: 0.44, // The line thickness
                pointer: {
                  length: 0.9, // Relative to gauge radius
                  strokeWidth: 0.035 // The thickness
                colorStart: '#6FADCF',   // Colors
                colorStop: '#8FC0DA',    // just experiment with them
                strokeColor: '#E0E0E0'   // to see which ones work best for you
              let target = document.createElement("canvas");
              let gauge = new Gauge(target).setOptions(opts); // create sexy gauge!
              gauge.maxValue = 3000; // set max gauge value
              gauge.setMinValue(0);  // set min value
              gauge.set(1250); // set actual value
              wrapper.appendChild(target);
             return wrapper;
      Any idea of what I’m missing here?
      Thanks a lot !
      • E Offline
        E3V3A @sispheor
        @sispheor Another wnaker repo talking about “cool looking JavaScript gauge” without a single picture on the page.
        "Everything I do (here) is for free – altruism is the way!"
        MMM-FlightsAbove, MMM-Tabulator, MMM-Assistant (co-maintainer)
          sispheor @E3V3A
          @E3V3A demo pictures are on the first link I left.
          But yes, the GitHub repo should also contains some.
          • C Offline
            Charley Module Developer
            You may need a start!
            start: function () {
            MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
              sispheor @Charley
              @Charley yes, I haven’t shown it but it’s present.
              • C Offline
                What is the code in your start.
                I expect you don’t add the wrapper to the dom
                  sispheor @Charley
                  @Charley here is the code
                  https://github.com/Sispheor/MMM-BMP-sensor/blob/dev/MMM-BMP-sensor.js
                  • C Offline
                    @sispheor Is everything invisible or just the gauge?
                    Do you see pressure or temperatures?
                    What is in your console.log from
                    console.log('adafruit_python_bpm.py results: %j', results[0]);
                      sispheor @Charley
                      @Charley Yes the table is visible. Only the gauge doesn’t appear.
                      • C Offline
                        Okay I might have an idea
                        Change your createElement part to
                        let mycanvas = document.createElement("div");
                        mycanvas.id=("divcanvas")
                        let target=document.getElementById("divcanvas")
