gauge.js
16 Posts 3 Posters 5.8k Views 3 Watching
    sispheor
    Hello guys, I’m trying to make working the gauge.js lib on my MM.
    Nothing appears on the screen. No error in logs or the console.
    Here is what I do, I just copied the content of the example available here.
    getScripts: function() {
            return ["http://bernii.github.io/gauge.js/dist/gauge.min.js"];
     getDom: function () {
            let wrapper = document.createElement("div");
            // add a gauge
            let opts = {
              angle: 0.15, /// The span of the gauge arc
              lineWidth: 0.44, // The line thickness
              pointer: {
                length: 0.9, // Relative to gauge radius
                strokeWidth: 0.035 // The thickness
              colorStart: '#6FADCF',   // Colors
              colorStop: '#8FC0DA',    // just experiment with them
              strokeColor: '#E0E0E0'   // to see which ones work best for you
            let target = document.createElement("canvas");
            let gauge = new Gauge(target).setOptions(opts); // create sexy gauge!
            gauge.maxValue = 3000; // set max gauge value
            gauge.setMinValue(0);  // set min value
            gauge.set(1250); // set actual value
            wrapper.appendChild(target);
           return wrapper;
    Any idea of what I’m missing here?
    Thanks a lot !
    E 1 Reply Last reply Mar 29, 2018, 5:15 AM Reply Quote 0
    • E Offline
      E3V3A @sispheor
      @sispheor Another wnaker repo talking about “cool looking JavaScript gauge” without a single picture on the page.
      "Everything I do (here) is for free – altruism is the way!"
      S 1 Reply Last reply Mar 29, 2018, 5:40 AM Reply Quote 0
        sispheor @E3V3A
        @E3V3A demo pictures are on the first link I left.
        But yes, the GitHub repo should also contains some.
          Charley Module Developer
          You may need a start!
          start: function () {
          MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
          S 1 Reply Last reply Mar 29, 2018, 1:44 PM Reply Quote 0
            sispheor @Charley
            @Charley yes, I haven’t shown it but it’s present.
              What is the code in your start.
              I expect you don’t add the wrapper to the dom
              S 1 Reply Last reply Mar 29, 2018, 1:51 PM Reply Quote 0
                sispheor @Charley
                @Charley here is the code
                https://github.com/Sispheor/MMM-BMP-sensor/blob/dev/MMM-BMP-sensor.js
                  @sispheor Is everything invisible or just the gauge?
                  Do you see pressure or temperatures?
                  What is in your console.log from
                  console.log('adafruit_python_bpm.py results: %j', results[0]);
                  S 1 Reply Last reply Mar 29, 2018, 2:40 PM Reply Quote 0
                    sispheor @Charley
                    @Charley Yes the table is visible. Only the gauge doesn’t appear.
                      Okay I might have an idea
                      Change your createElement part to
                      let mycanvas = document.createElement("div");
                      mycanvas.id=("divcanvas")
                      let target=document.getElementById("divcanvas")
                      S 2 Replies Last reply Mar 29, 2018, 3:29 PM Reply Quote 0
