    gauge.js
    16 Posts 3 Posters 8.7k Views 3 Watching
      sispheor @E3V3A
      @E3V3A demo pictures are on the first link I left.
      But yes, the GitHub repo should also contains some.
        Charley Module Developer
        You may need a start!
        start: function () {
        MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
          sispheor @Charley
          @Charley yes, I haven’t shown it but it’s present.
            What is the code in your start.
            I expect you don’t add the wrapper to the dom
              sispheor @Charley
              @Charley here is the code
              https://github.com/Sispheor/MMM-BMP-sensor/blob/dev/MMM-BMP-sensor.js
                @sispheor Is everything invisible or just the gauge?
                Do you see pressure or temperatures?
                What is in your console.log from
                console.log('adafruit_python_bpm.py results: %j', results[0]);
                  sispheor @Charley
                  @Charley Yes the table is visible. Only the gauge doesn’t appear.
                    Okay I might have an idea
                    Change your createElement part to
                    let mycanvas = document.createElement("div");
                    mycanvas.id=("divcanvas")
                    let target=document.getElementById("divcanvas")
                    S 2 Replies Last reply
                      sispheor @Charley
                      @Charley OK thanks, I’ll try this in a couple minutes.
                        sispheor @Charley
                        @Charley Doesn’t work…
                        Uncaught TypeError: Cannot read property 'getContext' of null
                          Maybe you could try this
                          let mycanvas = document.createElement("canvas");   // changed from div to canvas
                          I made a typo yesterday
                            sispheor @Charley
                            @Charley yes it’s what I tried…
                              sispheor
                              I tried with another lib called canvas-gauges. It’s the same. The canvas doesn’t appear on the screen
                              I’m wondering if a parent CSS config or something like could be the reason.
                                sispheor
                                It’s good it works!! For the last lib I just forgot to call the draw method.
