    No helper found for module:
    7 Posts 2 Posters 8.9k Views 2 Watching
    • R Online
      raymonvdm
      I tried to setup a RaspberryPi3 with MagicMirror but when i start MagicMirror i only get blankscreens.
      No helper found for module: helloworld
      This is the only module enabled in the config to rule out any specific module issue
        Mykle1 Project Sponsor Module Developer @raymonvdm
        @raymonvdm
        That just means that there is no node_helper.js for that module. That’s completely normal.
        Enable the clock, calendar, compliments and newsfeed modules. Those are the first 4 that should work initially after an installation.
        Lastly, are you getting errors in your terminal or console?
        • R Online
          raymonvdm
          I just copied config/config.js.sample to config/config.js and got the same messages about
          “No helper found for module:”
          pi@raspberrypi:/opt/MagicMirror $ npm start
          magicmirror@2.2.2 start /opt/MagicMirror
          sh run-start.sh
          Starting MagicMirror: v2.2.2
          Loading config …
          Loading module helpers …
          Initializing new module helper …
          All module helpers loaded.
          Starting server on port 8080 …
          Server started …
          Starting module: newsfeed
          Sockets connected & modules started …
          Launching application.
          The display turns black as it should be and there is no text output from the different modules.
          pi@raspberrypi:/opt/MagicMirror $ cat /etc/issue
          Raspbian GNU/Linux 9 \n \l
          RASPBIAN STRETCH WITH DESKTOP
          Image with desktop based on Debian Stretch
          Version:March 2018
          Release date:2018-03-13
          Kernel version:4.9
          • R Online
            raymonvdm
            I reinstalled using the installer and now it is working
            bash -c “$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)”
            Although autostart is not working (yet)
              @raymonvdm said in No helper found for module::
              That’s good news. :-)
              https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
              • R Online
                raymonvdm
                I already followed https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror but still not working. I will try a reinstall to see if it fixes anyting
                  @raymonvdm
                  If you reinstall, I believe there is an option for autostarting where you simple have to choose yes.
                  Otherwise, if you are setting up autostart manually,
                  Pay particular attention to this line:
                  PM2 will now show you a command you need to execute.
                  Most people miss this step. You have to execute the command that appears.
                  And lastly, you have to save the PM2 state
