    plz updated electron and spectron packages.
    Scheduled Pinned Locked Moved Feature Requests
    1 Posts 1 Posters 1.3k Views 1 Watching
    • L
      linuxni
      First, I’m sorry.
      I can not speak English very well.
      It depends on google translator.
      I do not use Raspberry Pi, but I tried several things because I wanted to use MM.
      After installing ubuntu 16.04 on vmware workstation, it worked successfully after installing MM.
      And odrold-ux4 succeeded and succeeded in artik530.
      After finishing the practice, I tried to install MM on artik710s and I failed.
      The problem is that the artik710s is arm64, although it is not accurate because it does not have expertise.
      In this regard, I wrote here.
      https://forum.magicmirror.builders/topic/6926/mm-installation-error-by-electron-arm64
      With my short knowledge, I think it would be possible to change the package below.
      1. electron version
        The package has an arm64 package starting at 1.8 or higher.
      2. Spectron version
        The electron-chromedriver package is installed with the spectron 3.7.x version.
        The electron-chromedriver also has an arm64 package starting at 1.8 or higher.
        The electron-chromedriver 1.8 package is installed with the spectron 3.8.0 version.
      I tried.
      Remove the package-lock.json file
      The package.json file was modified.
      "spectron": "3.7.x", -> "spectron": "3.8.0"
       "electron": "^ 1.4.15", -> "electron": "1.8.4"
      And when I did npm install and npm start, I could see the black screen.
      I know this project is Raspberry Pi, but I hope to use the two updated packages mentioned above in the next version.
      Thank you.
