    How can I inject some CSS styles in a block of text in Javascript so I can differentiate two different blocks of text
    2 Posts 2 Posters 1.2k Views 2 Watching
    • mediathreatM
      mediathreat
      Hi I’m kludging some code together, how Can i inject some CSS into this terrible piece of javascript I hacked together. I want to style the elements so that the title is different from the text. Here is what my screen looks like now - its the center piece about Super Troopers:
      alt text
      Id love to bold out "super troopers paul soter is a nimbly-bimly adman as a title to seperate it from the rest of it which is the text/description part.
      Here’s my code block that generates this:
      var ratio = Math.min(200 / Number(fix_width) , 200 / Number(fix_height));
      		var width = fix_width*ratio;
      		var height = fix_height*ratio;
      		var messageElement = document.createElement('div');
      		messageElement.className = 'light medium';
      		messageElement.innerHTML = "<table><tr><td><img src=" + image_bed + " /></td><td>" +  this.slackMessages[0].title + "</td></tr><tr><td>" + this.slackMessages[0].text + "</td></tr></table>";
      		return messageElement;
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @mediathreat
        @mediathreat you have different possibilities, e.g.
        add a class
        in your td tag add a class attribute class='MyFancyTitle', the forum don't want to render it. Then in your css you can style this class
        or add inline styling
        in your td tag add a style attribute style='font-weight: bold'
