MMM-Button doesn't work
18 Posts 3 Posters 12.2k Views 4 Watching
  • C Offline
    cruunnerr
    So i did the following:
    I succesfully updated npm to 3.10.8. Node told me it is up to date. then I deleted the MMM-Button folder with rm -rf. Then i follwed the install-guide again (clone folder, went to MMM-Button and npm Install), but get the same result as before! Is the Button-module not compatible with the newest Node/npm Version?
    What do you mean with deleting the node_modules folder in the MagicMirror directory? o.0 there are many many files. When i deleted it what should i do after that? i am a little bit scared, sorry for asking so many questions. ^^
    J 1 Reply Last reply Oct 1, 2016, 6:26 PM Reply Quote 0
      Jopyth Moderator @cruunnerr
      @cruunnerr This folder (MagicMirror/node_modules) was created during your installation, so you can safely delete it (but only this folder and everything in it. You just need to do the installation again (a npm install will create the exact same folders and files). Did you use the automatic installer script?
      Basically it looks like you have this problem. There are also some suggestions there.
      Helpful sticky: How to troubleshoot
      • C Offline
        cruunnerr
        So i will delet the node_modules folder in the magicmirror directory. then i go to cd ~/MagicMirrorand will do a npm install, right? should i do a npm update or “npm rebuild” before the install?
        edit: yes, i used the automatic installer
        J 1 Reply Last reply Oct 1, 2016, 6:31 PM Reply Quote 0
          @cruunnerr Yes, that sounds about right, you can try the rebuild thing first.
          • C Offline
            cruunnerr
            ok, will try tomorrow and report ;)
            thank you very very much for spending your time
            • C Offline
              cruunnerr
              so, i tried everthing but cannot get it work at all. tried it many times…but every time i did the “install” i got some warnings. tried to get them away with install the newest versions and it shows me that it was succesfull, but always get the same warnings… dont know why and if they are significantly.
              edit: why others dont have this problem? I used the “complete setup tutorial”. or is it cause i used the automatic installer?
              • C Offline
                cruunnerr
                no more ideas?
                • ? Offline
                  A Former User
                  I had the same issue and was able to fix it.
                  You need to execute electron-rebuild.
                  Just follow these steps: https://github.com/electron/electron-rebuild
