    MM Shows a plain Black Screen on iOS 9.3.5 device
    29 Posts 12 Posters 14.7k Views 11 Watching
      shiroe
      Hi all,
      So to be as specific as possible in case it helps, I’ve setup MM on an RPi recently and have this working in the house in SERVER MODE.
      This setup works successfully on Andriod/PC devices without issue.
      However the iPad 2 (iOS 9.3.5) device I had lying around and target for this build actually wont show the page content, it loads in Safari/Firefox/etc and displays a black screen which I believe is the back ground colour but no content is visible (per below).
      iPad Image [Imgur]
      To test my setup I’ve checked using an iPhone 7Plus on iOS 10.2.1 which works, thus confirming it’s not an issue with Apple devices in general & just the iPad - or more likely the iOS release?
      iPhone Image [Imgur]
      If anyone has any ideas here I’d love any assistance at this point.
      I’ve tried googling similar ios9.3.5 issues and checked the MM forum as well but can’t find any other mentions of this
      EDIT: yes the port 8080 is there, Safari just hides it when you don’t highlight the address bar
      EDIT2: iPad has been factory reset in case it helps, it’s also not jailbroken
      S T idoodlerI 3 Replies Last reply Reply Quote 0
        shiroe @shiroe
        @shiroe
        EDIT: if someone can confirm how to fix the above with a direct image rather than just link I’ll edit original post and remove this one.
        • T Offline
          thobach @shiroe
          @shiroe I have the same issue as you and would be grateful for a resolution. I suppose the issue is related to the old Safari version on iOS 9.3.5. I’d also accept a workaround that requires a jailbreak of the iPad 2.
          • idoodlerI Offline
            idoodler Module Developer @shiroe
            @shiroe Mobile Safari on iOS 9.3 is obviously missing some features. If a module is using a function not supported by this version of Mobile Safari a black screen might happen.
            You only can debug this using Mac.
              shiroe @idoodler
              @idoodler FYI default modules only it still shows the same, I have a bit more time tomorrow so I’ll try reducing one by one to see if i can find exactly which doesn’t work - though I feel it’s likely going to be all of them
              • P Offline
                Pipe-line
                Same problem here… iPad 2 with iOS 9.3.5 and I’m getting a black screen… I tried with Google Chrome, Dolphin Browser but no good luck.
                A work around: Install VNC Server on RPi, and a client on the iPad. Go to fullscreen mode, and voila!
                idoodlerI 1 Reply Last reply Reply Quote 0
                • idoodlerI Offline
                  idoodler Module Developer @Pipe-line
                  @pipe-line I think we have an iOs 9 device at work. I will debug it tomorrow night. What modules do you have installed?
                  • P Offline
                    Pipe-line
                    @idoodler I started with Current Weather and Weather Forecast and then only with Current Weather, but no lucky.
                    Thanks!
                    • idoodlerI Offline
                      @pipe-line ok. I just gathered the iPad. Its an iPad mini running iOS 9.3.3. I hope I won’t forget it until I get home:)
                      • idoodlerI Offline
                        Issue has been identified. I am just preparing a pull request. Hold on tight!
                        • idoodlerI Offline
                          Lol. This issue has already been fixed on the 8th of April 2018 by Chris Pickett. It is available on the develop branch. It eventually will be merged with the masterbranch.
                          • P Offline
                            Pipe-line
                            @idoodler thanks! I will try develop branch this night :)
                            • T Offline
                              thobach
                              I also identified the issue. It is related to the use of Promises, a feature of ECMAScript 6, which is not supported by iOS 9.3.5. The feature is used in multiple javascript files that are built into the core of MagicMirror2. I believe it can be fixed with a polyfill.
                              • idoodlerI Offline
                                idoodler Module Developer @thobach
                                @thobach I don‘t think its an issue with the promise itself, but rather with the arrow (=>) operator that defines the callback.
                                • T Offline
                                  thobach @idoodler
                                  @idoodler True! It was fixed in https://github.com/MichMich/MagicMirror/commit/6bb4db38428af7ac46a6f4240ab9cfe4bf9fcbea and I can load now the default configuration on iOS 9.3.5 again.
                                  But I can still find one use of “=>” in the develop branch: https://github.com/MichMich/MagicMirror/blob/fb0cc61e09542533affa92b1e8bd6f9a2aca6363/js/module.js#L84.
                                  • idoodlerI Offline
                                    @thobach that link you posted points me to a specific commit. I can not find any use of the => operator in the browser part In remote/develop
                                      shiroe @idoodler
                                      @idoodler so just to clarify, this has been found and due to be fixed?
                                      or did i totally misread that…
                                      if so can’t wait for new release!
                                      EDIT: pardon my manners, thank you for checking this out as well :)
                                      • idoodlerI Offline
                                        @shiroe This issue has already been fixed on the active development branch. Its basically ready and will be available on the next release.
                                        You can already test this fix by switching to the develop branch, but be carefull, this branch is still under active development, hence the name;)
                                          shiroe @idoodler
                                          @idoodler thank you very much again, will keep an eager eye out for this one!
                                            realthinx
                                            I had also an issue with the default calendar module on an iOS 9.3.5 iPad. It could not be rendered. On debugging the iPad Safari with my MacBook i found the reason here: modules/default/calendar/calendar.js, Line 439.
                                            for(let evt of eventList){
                                            should be
                                            for(var evt of eventList){
                                            so that older browsers can render the module without error. Would be great if you can add that for the next release :folded_hands:
