    MMM-DHT22 Humidity and Temperature Module
    47 Posts 14 Posters 46.9k Views 14 Watching
    • DocVooDooD Offline
      DocVooDoo
      Hey, i have the same problem.
      With “./Adafruit_Python_DHT/examples/AdafruitDHT.py 22 27” comes the Temperatur “Temp=20.1* Humidity=29.3%”
      The DHT22 is Pinned on PIN 13 (27) (WiringPi 2). On the Mirror is the Temperatur and the Humidity undefined.
      Whats the Problem? I found nothing…
        ryck Module Developer @DocVooDoo
        @DocVooDoo Then I don’t know, maybe there is something wrong with the module…
        Have you tried mine? https://github.com/ryck/MMM-DHT-Sensor
        DocVooDooD 1 Reply Last reply Reply Quote 0
          DocVooDoo @ryck
          @ryck Hi. yes, a minute ago. He says “no data returned”.
            @DocVooDoo sometimes the raspberry pi needs some time to pick up the values… try to increase the update time (ie, 30 seconds) and wait for it to update a couple of times…
              DocVooDoo @ryck
              @ryck nothing has changed. i have “node serveronly” running, and the log says “Error: failed to read sensor at Error (native)”
              but the sensor works… look
                @DocVooDoo Weird… did you follow all the instructions? ie, install bcm2835, npm install, etc?
                  DocVooDoo @ryck
                  @ryck Yes of course.
                    @DocVooDoo No idea then… Can you paste here the error you get?
                      DocVooDoo @ryck
                      @ryck only this Bild Text
                      then nothing on the log in node serveronly screen
                        @DocVooDoo well, no idea then… Have you tried to run the normal version (instead of the serveronly)?
                        DocVooDooD 2 Replies Last reply Reply Quote 0
                        • 4 / 5
