    MMM-DHT22 Humidity and Temperature Module
    47 Posts 14 Posters 52.0k Views 14 Watching
      Johans @ryck
      @ Bangee
      installed modules as described in read.me file but I get no reading of temp or hum.
      sensor is working, tested with AdaFruit example
      sudo ./AdafruitDHT.py 2302 27 (Data connected to gpio 27)
      I get a perfect temp & hum reading, so i’m shure sensor is working.
      i’m using an RPI3 - according to wiring pin, wpi 2 = gpio27 = physical pin 13.
      I think wiring is OK.
      only clock and this module installed.
        PaulB
        Hey guys :) Hope you are all good.
        Finally I have the time to work on this module again :)
        I had the same errors like you before and unsuprisingly did not found a solution for it.
        Is someone in this thread still active?
        J 1 Reply Last reply
          Johans @PaulB
          @PaulB - glad you have found some time to work on it.
          Yes I still have the problem with reading the data in the MM.
          Hope you can find the cause. I would like to help you, but i’m not a programmer.
          The only thing I could help on is perhaps some beta testing.
          Cheers.
          Johan
          • DocVooDooD
            DocVooDoo
            Hey, i have the same problem.
            With “./Adafruit_Python_DHT/examples/AdafruitDHT.py 22 27” comes the Temperatur “Temp=20.1* Humidity=29.3%”
            The DHT22 is Pinned on PIN 13 (27) (WiringPi 2). On the Mirror is the Temperatur and the Humidity undefined.
            Whats the Problem? I found nothing…
            R 1 Reply Last reply
              ryck Module Developer @DocVooDoo
              @DocVooDoo Then I don’t know, maybe there is something wrong with the module…
              Have you tried mine? https://github.com/ryck/MMM-DHT-Sensor
              DocVooDooD 1 Reply Last reply
              • DocVooDooD
                DocVooDoo @ryck
                @ryck Hi. yes, a minute ago. He says “no data returned”.
                  @DocVooDoo sometimes the raspberry pi needs some time to pick up the values… try to increase the update time (ie, 30 seconds) and wait for it to update a couple of times…
                  • DocVooDooD
                    DocVooDoo @ryck
                    @ryck nothing has changed. i have “node serveronly” running, and the log says “Error: failed to read sensor at Error (native)”
                    but the sensor works… look
                      @DocVooDoo Weird… did you follow all the instructions? ie, install bcm2835, npm install, etc?
                      • DocVooDooD
                        DocVooDoo @ryck
                        @ryck Yes of course.
                          @DocVooDoo No idea then… Can you paste here the error you get?
                          • DocVooDooD
                            DocVooDoo @ryck
                            @ryck only this Bild Text
                            then nothing on the log in node serveronly screen
                              @DocVooDoo well, no idea then… Have you tried to run the normal version (instead of the serveronly)?
                              DocVooDooD 2 Replies Last reply
                              • DocVooDooD
                                DocVooDoo @ryck
                                @ryck yes, the same problem…
                                • DocVooDooD
                                  DocVooDoo @ryck
                                  @ryck is it possible that the module root rights needs but does not get?
                                  with another module comes the same error. root privileges are needed there
                                    @DocVooDoo I guess that depends on how you installed magicmirror… did you use sudo?
                                    • DocVooDooD
                                      DocVooDoo @ryck
                                      @ryck no, without sudo. only with the command
                                      bash -c “$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)”
                                      • yawnsY
                                        yawns Moderator
                                        Some modules or dependencies require access to the GPIO
                                        The DHT sensor module I wrote needs this as well.
                                        In terminal please try this
                                        sudo adduser -g $USER gpio
                                        I can’t remember if you need to reboot afterwards, but it won’t hurt. Then try again accessing the sensor
                                        • DocVooDooD
                                          DocVooDoo @yawns
                                          @yawns
                                          Hi. Thanks for your help. The user “pi” is already a member of the group “gpio”.
                                          With Adafruit works the Sensor. Whether with or without sudo…
                                            pinsdorf Module Developer
                                            Any updates on this? I have the same problems as @DocVooDoo and others, i.e. Adafruit code works like a charm, dht_var not.
                                            Difference I noticed is that dht_var uses wiringpi library and Adafruit not?! I tried a reinstall of wiringpi package without success.
                                            Next, I compared the implementations of dht_var and the Adafruit driver for DHT22.
                                            The essence of the Adafruit code is in file Adafruit_Python_DHT/source/Raspberry_Pi_2/pi_2_dht_read.c. It is meant for Pi2 and Pi3, implemented in C, and defines a function int pi_2_dht_read(int type, int pin, float* humidity, float* temperature). It implements the communication with the sensor using a 1-wire bus. The rest of the Adafruit package is mostly (well-done) sugar-coating for Python usage and selecting the right driver for any given platform.
                                            We could simply rewrite dht_var by using this driver code. What do you think?
                                            • 2 / 3
